Stuck In 1st Gear
Discussion in 'The Garage' started by D1BADB, May 22, 2006.
  1. D1BADB
    D1BADB Registered Member
    May 22, 2006
    9
    SAN JOSE, CA
    Hello all, I have an 1889 blazer AT all stock internals and am having a problem with my tranny. I have heard that these year trucks with the 700r4 have a specific problem in which it keeps the truck in 1st gear. It just happened all of a sudden. I can go in reverse and when i put it in D it will rev up and stay in first gear without shifting up. If anyone has heard of this or has some troulbeshooting ideas i can do without taking it to the tranny man please let me know., thanks
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Your governor gear is prolly stripped. Easy & cheap to fix. Governor is located behind a big round cover on drivers side towards the back of the tranny. Just pry off the cover and remove the gear and weights. You can get a new gear at any tranny shop or the whole governor kit is usually around $15.00- $20.00 Make sure you get the gear/kit for a 700r4. not a TH 350 they look the same but are different.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Most likely the plastic gear on the governor is chewed up. It's pretty easy to swap. It's behind a round cover on the drivers side of the trans. Gently pry the cover off and you can pull the whole assembly right out and see if it's damaged. :)
  4. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    That's what happened to me a couple summers ago.
    On the freeway doing 75mph when all of a sudden it slams into 1st.
    Had 1st and reverse only.
    This is what the govner looked like.
    It cost me $12.00 for a new one from the dealer.
    You get the new gear and a new roll pin.The pin is what keeps the plastic gear on.
  5. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    And unfortunately when this was offered as a possibilty to me I found about 1/4" of metal filings in the bottom of my pan. :-) but that was a K5 ago...
  6. D1BADB
    May 22, 2006
    9
    SAN JOSE, CA
    Thanks for all your help guys, I will pull that part this weekend and hopefully it is chewed up and replace it, Thanks again for that pic so i know what im lookin for....
