Stuck in Mud. HELP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Innerpiece, Feb 27, 2001.
  1. Innerpiece
    Innerpiece 1/2 ton status
    Feb 22, 2001
    145
    Mississippi (Yee Haw)
    Hi all --
    I got my 87 Blazer stuck in some good clay mud up to the doors. I've had some other large trucks try to winch me out to no avail. Commercial Rigs can't get close because I'm about 1/4 mile from a road. I need help bad, as its supposed to rain the rest of the week and there's a good possibility that my truck could be underwater soon. Any suggestions would help, I'm going out to start shoveling soon.
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I would start shoveling, and try to jack it up and put something under the tires(rocks work good). When you get all the mud outta the way, get some of your buddies to try winching/yanking, should be easier w/out all the mud in front of the truck
    Murphy's Laws on Life :
    "Leftover nuts never match leftover bolts." [​IMG]
  3. wi86blazer
    wi86blazer Registered Member
    Oct 20, 2000
    35
    Wisconsin
    Any farms in the area? If so, ask for help, a farm tractor is nearly as good as a dozer for pulling...
  4. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    Try jacking it up and putting some small logs under the tires, then winch with a snatch block. Breaking the initial hold is the toughest part.
    [​IMG]<font color=red> Elkboy</font color=red> [​IMG]
  5. Innerpiece
    Feb 22, 2001
    145
    Well -- thanks for the advice ... I'm going to try digging it out some, but I don't think I can jack it up because its nice grey soft clay all the way down to the center of the earth. As far as farm tractors ... won't the tall skinny tires in the rear just sink in upto the axles? won't the front end get buried? Any other suggestions? I have to dig some because the tires are just spinning and not digging any farther down ... its floating on the frame.
  6. Innerpiece
    Feb 22, 2001
    145
  7. Dragworm
    Dragworm Registered Member
    Feb 1, 2001
    80
    Dallas, TX
    If you can find the farmer that's willing to help you he'll know if he can make it. I watched a farmer who did day hunts pull 5 cars out of his fields after an unexpected rain storm and that was the black gumbo Texas mud in plowed fields.
    So, which one of you is the brains of the operation?
    To tell you the truth it's not exactly a "brains" type operation.
  8. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    What are your tires like? Do you have bald stock tires? ..... good stock tires ..... or maybe some oversize tires?
    I got my truck stuck in some very soupy mud the 1st week I had it. It had some street (car) tires on it. To get it out, I changed the rear right tire to a 31" mud terrain and worked my way out by digging channels in the mud and rocking back and forth it took me about 6 hours all-in-all to get it out. Read my story http://Stoopalini.coloradok5.com
  9. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    Kinda hard on your rims, but you can lay a log across the rear behind the wheels then take a chain and go through the holes in your rims and around the log on both rear tires. with this attached put the truck in reverse. and by backing up about two feet the log will lift the rear tires out of the hole and you can fill it with stones or what ever. Just make sure to stop before the log binds against the springs so you can get it loose from the rims and repeat if necessary. You might could also use nylon rope so as to not scar up your rims especially if they are aluminum.
    I thought I was wrong once,
    but I was mistaken
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Many years ago I was camped at Utah lake. This guy that was with us had a 2WD International Travelall. He got up early on Sunday morning and decided to head home. So instead of dragging his canoe up the beach, he decided to drive his rig down to the waterfront and load the canoe there. You could stand on the beach, wiggle your feet and sink to your knees in just a few seconds. Needless to say, the Travelall was STUCK! Sitting on the frame.
    We chained 5 4WD's together end-to-end to form a train and then we pulled that beast out of the mud. It had the old straight I-beam front end that acted as a bulldozer blade as we pulled him out. But having 20 tires digging and pulling made it pretty easy to get him out of there.
    Can you get several trucks out there with enough chains and straps to do something like this? Just make sure that the tow strap on your truck is attached to a VERY strong spot! [​IMG]
  11. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    Innerpeace,
    Where are you located. I'm in Valdosta GA, and will be headed back to NC on Thursday. You may have had other trucks try and pull you out, but I'd like to give it a try. Its not always about the size, but more about Technique. Good thing i've got both [​IMG]. If you aren't too far out of the way, I'd be willing to lend a hand. I'm planning on taking 95 north out and up to NC. If this will be of any service, let me know.
    As far as a self recovery technique, I"ve never tried this, but if the tops of the tires are showing, thread some heavy duty rope through the holes nearest the outside of the rim, thread them through a recovery strap on each side. (both fronts or rears) and as straight as possable, anchor the other sides. Keep the tires straight, and go SLOW, just put it in gear as the tires spin, it will wrap the strap around the tire. Something has to give. Hopefully the anchor before the axles or driveshafts, but its just a theory of mine. I've never had to try it. A HS95i and snatch blocks w/ lots of straps has served well.
    Best of luck.
    Corey
    88K5
    [​IMG]<font color=red>Girls Like Guys In Bow Ties
    <A target="_blank" HREF=http://www.geocities.com/corey_perez>http://www.geocities.com/corey_perez</A>
  12. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    If you get majorly desperate call in the huey haha!
  13. bigblue
    bigblue 1/2 ton status
    Dec 6, 2000
    658
    southern california
    Dig, Dig, Dig and Dig some more. Get that puppy out before the rains come!!!
    baja surf nazi -...A late storm NEVER comes...
  14. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    What I have always done is shovel....shovel...
    I also have 5 blocks of 4x4 wood in the back....take one block of wood and attempt to use that as your jacking point. If you need put 2 of em together and make an X out of em. Put everything you can under your tires.
    I use the blocks of wood I have in the back. If you can get it up just a bit you can usualy move it. I only got one stuck...and I didn't have woody with me...oh gawd...that sounds bad...
    SK-15
    J**P...it's whats for dinner!
    <A target="_blank" HREF=http://SK-15.coloradok5.com>http://SK-15.coloradok5.com</A>
    Roads? Where we're going, we don't need any roads!
  15. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    winch and snatch block, if not get someone who knows what there doing out there. like they said it's more about the experience
    Doug Krebs
  16. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    THIS HAS HAPPENNED TO MY 98 2500 SUBURBAN- I BROKE A 10,000 LBS TOW STRAP. U NEED AT LEAST A 20,000 LBS TOW STRAP AND SOMEONE W/ A 454 OR SOME SORT OF 3500 TRUCK, HE WILL NEED TO CREATE SLACK, AND THEN FLOOR IT. THIS IS NOT TOO GOOD FOR THE EITHER TRUCK, BUT IT WORKS!!!!!!!!! I DID IT A COUPLE OF TIMES AND IT GOT THE BURBAN OUT OF THE MUD. DO THAT ALONG WITH DIGGIN IT OUT.
    LATER
    PHILL
  17. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if you do the above meantioned idea that dose work by the way DO NOT USE A STRAP WITH TOW HOOKS ON IT AND DO NOT ATTACH TO TRAILER HITCH BALL either itam will shoot back if they break
    s.smith 77blazer lookin 4 mud [​IMG]
  18. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    10,000lb strap??, I didn't even know they made those [​IMG]. I wouldn't use anything under 30k
  19. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    If you do have to use a strap with hooks or attach the strap to a ball, be sure to put a coat or something on the strap so whe nit breaks it will fall and not throw things at you.
    90K5
  20. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I don't know if they have any logging operations down there but you might check. If they have a skidder within a couple of miles they might help you out. We had two of the family trucks stuck in the clay on a landing here in N. Calif. and ended up leaving them until everything dried out. I really feel for you since I know that stuff doesn't want to let loose of anything it has in it's grasp.
    SMSgt Smith
