Stuck in reverse
Discussion in 'The Garage' started by dapert, Nov 20, 2005.
  1. dapert
    dapert Registered Member
    Jun 10, 2003
    12
    Did a steering column swap today on my '85 Suburban and when I started it up it jumped back about 4 feet because it was in reverse. It was in park on the steering column so I'm not sure what gives. I'm a little afraid to mess with it and try it again until I know for sure it's in park.
    Any suggestions on what went wrong or how to know for sure if it's in park?
  2. Hermy13
    Hermy13 Registered Member
    Aug 27, 2005
    22
    Iowa
    on the rod that comes off the steering shaft by the engine there is a rod that goes to the tranny that should have a bolt in it to adjust to make it longer and shorter thats most likely your problem
  3. dapert
    Jun 10, 2003
    12
    I know the rod you are talking about. I could feel it seem to change gears when i pulled on it it hook it back up. Is there any way to know for sure how many pulls or at what position it ends up to ensure it's in park?
    Obviously I'm afraid to start it again unless I know for sure that it's in park.
    Any way to know for sure it's in park?
  4. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    crawl under the truck, the lever on the tranny should be all the way forward when in park, put the colum in park and see if it needs any adjustment when you try to bolt it up.
