Stuck Mid-Project... Please help. :)
Discussion in 'The Garage' started by colbystephens, Dec 6, 2006.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    so i'm trying to replace the ujoints on my front driveshaft, but i'm not familiar with this style of ujoint at all. how do i take it apart? do i just get under the caps w/ a screw driver and pry them upwards (away from the center)? rather difficult to do it that way. i already removed the c-clips. ???
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    that setup is a pain in the a$$ to replace. I wait until they are obviously bad to replace them. The right way is to use a press. But a well placed hit with a hammer is what most people use.
  3. black sheep
    black sheep Registered Member
    Nov 7, 2006
    41
    Va Beach
    1st you will never pry them out with a screwdriver you must beat them to death.also the little plastic bubbles on the drive shaft are bonding? from the factory.you have to heat the area with a torch untill all of that oozes out,which will make it much eaiser
  4. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ok, i'll torch it and beat the hell out of it tomorrow! thanks!!! :)
  5. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i'm not seeing how hammering the hell outta that is going to make the joints move. since it has c-clips, shouldn't the caps come outward, rather than inward?
  6. black sheep
    Nov 7, 2006
    41
    Va Beach
    you have to move the joints each way to get the caps out.I usually place a socket under the cap and beat either the shaft or flange to get it moving
  7. k30bb468
    k30bb468 1/2 ton status Premium Member
    Oct 2, 2004
    955
    NW Pennsylvania
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Yup , clean and simple , the only way :bow::bow:
    I haven't bought one yet , well maybe I did , I have the Autozone loaner here . The p/o of my tow rig meant well , and has the receipts from buying the joint , and it says GMB ............ but he didn't know jack about installing them right . I got one roller and a pound of dust :eek1:
    Anyway the CV's aren't all that intimidating , just mark the shaft pieces for oreientation , and press out the bearing caps . Its only more invloved if the ball or socket is fubared .
  9. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Ya can borrow my press if ya want, I sent ya a PM.
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    You do them just the same as a normal UJ but there's 2 of them and a small amount of spring pressure between them. Just use a press and push the cross through one way, remove the cap sticking out then push it back the other way etc. Not rocket science but a bit fiddly on your own so if you've got a buddy to help, all the better.
    WARNING: Do NOT get your wife to help. UJ + wife = broken nail .....not worth the grief!!:D
  11. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
  12. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    I didn't read all the answers on this post, but i just did mine and this is what i found to work nice.
    Get a sockets set and a vise. use a socket smaller than the dia. of the u-joint bearing housing.
    close the vise on the the socket pushing the u-joint about 1/8". This will allow you to use the vice to support the socket while adding a socket to the other side that is bigger than the u-joint bearing housing. then close the vise on both socket pushing the ujoint housing into the bigger socket. remove the housing and repeat for the other side.
    Hmmm, it's really pretty ez, but as i proof read what i just wrote now i've confused myself :doah: .
    the front is tougher cause it kind of a puzzle the way it goes together but it's also pretty straight forward.
    The hardest part is trying to hold 2 sockets, 1 drive shaft and close the vise.
  13. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ok, guess i'll trust you guys. just seems that it won't want to move due to the way its in the joints. :) maybe i'll take lots o pics of the process so other dudes can have a picture story for future reference for other noobs. :)
  14. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Make sure you get a few pics of when you squish your fingers between the 2 joints........just so others will know not to do it!:D
  15. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    been there already.
  16. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    this is hard to explain over a computer. If you watch someone do it in real life it is simple.
    First heat the snot out of it to get all the plastic bonding out.
    You need to use the U-joints themselves to push the caps out. I use a hammer and a vise. but there are methods that use a little more finess.
    Find someone you know that has changed U-joints and have them guide you through it.
  17. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    i dunno if this helps but here
  18. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    yeah, i'm familiar with how to remove a ujoint - done it a few times. i just figured that with a cv set up, the yokes would prevent lateral movement, and thus i was confused. anyway, got this all taken care of. i'll share some funny stories about it later (i.e. how to turn a driveshaft into a u-joint cannon).
  19. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    there is a ball pivot contraption in between them......it is a giant pain in the ass. and if the pivot is worn out putting new joints in is a waste of time and money. so make sure. I use the vice as a press with a socket.
  20. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
