Stuck NP205? neeed help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kickinasphalt383, Feb 13, 2002.
  1. kickinasphalt383
    kickinasphalt383 1/2 ton status
    Dec 6, 2001
    224
    Michigan
    hey
    i just swapped in a SM465/NP205 combo and when i shift the t-case into 4hi or 4lo and use it for a while it is UNBELIEVABLY hard to shift it out and back into 2wd. some times it shifts out normally, but not too often. whats goin on?-thanks
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    You probably have the tranny in gear, putting a load on the whole drivetrain. Simply throw the tranny in nuetral and then shift the t-case. OR: You may sometimes need to roll back a little to disengage everything. This takes the load off everything while it's all in the forward motion. If you take some slack out in the backwards motion, it will allow some 'play' to allow the shifting.
    Just my .02. [​IMG]
    <font color=red>Only real men drive K30's!!!</font color=red> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  3. kickinasphalt383
    Dec 6, 2001
    224
    Michigan
    well i have tried it in gear and in neutral, doesnt make a difference. i will try the rolling back thing. does the 205 act that much different than my old 208? my 208 shifted with ease? thanks again
  4. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Yep, welcome to the NP 205 gym program. In a couple of months and you'll have a right bicept like a prize fighter!
    Eric M.
    Blown K3500 [​IMG]
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    shift it while moving but with no torque on it.
    formerly 77chev
    still a jerk though
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    The Detroit in the back for some reason has something to do with it. A locked rear only seems to make it worse. Try what MJ said and also try rocking the truck back and forth.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have just about perfected the "205 shift on the fly". When I am in 4lo and need 4hi or 2wd I just keep rolling, shift into N (with the trans), shift the 205, and go back into D (with the trans).
    When I first got the truck I tried alot of ways to get it to shift (including putting my foot on the lever and pushing!) but this way was the only way that worked every time. It is also fast and better than your friends almost rear ending you because you stopped on the trail to shift!
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  8. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Yep I just stab the clutch and it slides right into whatever I want.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  9. kickinasphalt383
    Dec 6, 2001
    224
    Michigan
    thanks for all the help guys, i was getting worried i swapped in a broken 205, but i guess its all normal. thanks again
  10. Big_B_Murphy
    Big_B_Murphy 1/2 ton status
    Dec 28, 2001
    159
    New Stanton, PA
    It is one of the tradeoffs. Strength vs ease of use. I will go with strength every time.
    <font color=red> It is just as much fun to build it as it is to bash it</font color=red>
  11. 1Blazin71
    1Blazin71 1/2 ton status
    Aug 23, 2000
    112
    Los Angeles
    I was taught that you can shift the 205 either stopped in N or rolling in gear with no throttle and by "yanking it like a man".
    Works for me.
    Matthew Meyer
    matthewm@inhollywood.com
    '71 Ochre K5 - 4" Lift 35"s
    ZZ4 350 - 700R
