Stuck on motor swap again... Torque Converter spinning freely
Discussion in 'The Garage' started by 78Suburban, Dec 13, 2005.
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    All I have left to remove are the 3 TC to flywheel bolts and the 2 motor mount bolts.. I put a wrench on the flywheel to TC bolt, and the whole thing just spins when I try to pull down on it? How in the world can I manipulate it to not spin? I thought about jamming a long pullhandle wrench on the front crank bolt, or jamming something against my flywheel, I just need to stop it from spinnign freely when I try to remove the bolts..
    I am currently convered in grease and sand and all kinds of crap. I am working my flashlight now. Suggestions are VERY welcome.
    thanks :bow: :bow: :bow: :bow: :bow: :bow:
    James
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Use something against the flywheel teeth and anything immobile . Loosening those bolts shouldn't break anything .
  3. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    what should I use against the flywheel teeth? a board maybe?
    thanks,
    James
  4. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    ttt, its getting cold out there.. I would like to at least get these 3 bolts tonight
  5. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you can use a long screw driver or what i have been doing is where the starter would be get the bolt in that area and use a rachet the rachet will hit against the oil pan alowing to to get the bolts loose with out having to use a screw drive and a wrench in the other hand
  6. 1-ton
    Apr 17, 2004
    2,884
    162
    Las Vegas, Nevada
    There is a special tool just for holding flywheels in place. What I have done on the past is wedge a pry bar (or large screw driver) up in between the crank and flywheel crank bolts to hold the flywheel in place.
  7. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Just did that, and it worked awsome. This place really is the best tool I have for wrenching :bow: ............ tomorrow morning I will pull the 2 motor mount bolts and lift that low oil pressure, crapping running, SOB out of my truck :D ... then I'll drop in a good running 350 I got from clarkjw24 :D
    Thanks,
    James
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Or, put a wrench on it, hold on tight, and have someone hit the ignition! :D
    I always just found a way use the wrench that wouldn't put force on the flexplate in a direction that makes it spin. You can make things work against themselves to your benefit sometimes.
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I found a special tool myself , a GT bmx bike straight seatpost . Its 4130 chro mo , thick walled . I flattend one end for prying , and the open end holds my 3/8 ratchet and is my leverage . Very versatile . Hood prop , jack handle , self defense , flywheel stopper :D
    The best tool I ever found !
  10. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    i unbolted the converter from the flywheel, just last week. to get the bolts moving, i just used some basic physics principles. i positioned the flywheel and wrench in such a way that i was applying force perpendicular to the tangent (pushing towards the crank), not at a tangent to the flywheel. i should mention that i had already pulled my oil pan. that is worth the hassle, because it allows so much more room to move and see.
  11. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The real fun starts when you get to the installation. Turning over the engine so that you can tighten all 3 bolts is a great time. ;) Having a flywheel tool makes the job WAY easier.
  12. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    He's actually got a flexplate, not a flywheel lol
  13. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    i have put vice grips on the crank pully before, and let the belt/pully/vicegrips bind the motor as i pull on the wrench
  14. sebban
    sebban Registered Member
    Jan 18, 2005
    63
    sweden
    [sort of hijack]
    Does the diesel converter bolt up to the petrol flexplate? (3 bolts)
    [/sort of hijack]
  15. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Wow I never really had that much trouble getting the bolts out or in for that matter. It would be alot easier if that motor your pulling has good compression, usually that is enough to get the bolts out. It might spin a little bit but usually they come out.
  16. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    I already got them out by letting the wrench butt up against the oil pan, as suggested earlier in this thread. Heck I already have the motor out.. I just need more time to put the new motor in, but with finals at college, I'm a little short on time.
    BTW:the engine had the belts removed and the spark plugs removed ;)
    thanks,
    James
  17. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    Remove 1 spark plug,,,,insert 1 ft of 3/8 nylon rope into hole,,leave some hanging out,,roll engine over until rope is compressed by piston against cylinder head,,,remove torque converter bolts,,,roll engine back a few degrees and pull out rope from plug hole
  18. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Thats a very good idea, probably a good idea to do it on the compression stroke so that way there is no possibility to get the rope stuck in a valve or even possibly damaging the valve.
