Stuck Spark Plugs
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jc71355, Aug 7, 2002.
  1. jc71355
    jc71355 1/2 ton status
    Jan 13, 2002
    830
    Port Neches, Texas
    What do Ya'll use to get stuck spark plugs out? I've tried WD40, Burlite, and some other stuff we had laying around and nothing worked. The PO put split sh!t plugs in there and I've got a bad miss so I'm guessing that's my problem. Any idea's are appreciated.
    James
  2. dyeager535
    26,979
    You've tried removing them when the engine is still hot or warm? The expansion/contraction difference in the metals should make it a bit easier shortly after driving the vehicle.
    I've never heard of an honest to goodness stuck plug, there really should be no reason for them to be stuck that tight. Hope they didn't loc tite them in there or jb weld a stripped plug hole!
  3. jc71355
    Jan 13, 2002
    830
    Port Neches, Texas
    Uh... Yea me too /forums/images/icons/frown.gif /forums/images/icons/crazy.gif . I will try it with the motor warm. Thanks for the tip.
  4. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    Did you try pb blaster it works alot better than wd-40.
  5. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    ZEP spray works. Have you tried tightening it and then loosening it? Once in a while this works. I'd give others' suggestion of trying it after you've driven it as well. Things like this is what makes me smile when I use anti-seise on mine. haha. Sorry to laugh at your misfortune.
