stuck timing gear
Discussion in 'The Garage' started by cheyennesuper, Nov 18, 2004.
  1. cheyennesuper
    cheyennesuper Registered Member
    Nov 2, 2004
    52
    Wisconsin
    I'm trying to pull off the bottom timing gear(the smaller one on the shaft)off of a chevy 350 but it won't budge.Autozone gave me a puller with the two bolts as if the gear had threaded holes for them but there is no bolt holes in the gear.I tried using a gear puller with the hook-arm things and even rapped on the puller shaft with a hammer but the damn gear won't move a bit.Does anyone else have any ideas?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it might be posible the woodruff key slipped in the slot and is now wedging against the gear preventing it coming off. try tapping it back on and them pulling it off again.
    i always use a 3 jaw puller, never failed me.
  3. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    How bout a 4" grinder? Make two cuts 180 degrees apart as deep into the gear as you can without kissing the crank snout-next cold chisel in the cuts and a couple of raps with a 4LB hammer,Hopefully it will split right off.
  4. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    Thats how i get stubborn ones off,if you are replacing it. I have just given them a good whack with a sharp cold chisel right above the keyway,and they crack pretty easy--in fact,after you install a new one be SURE it didnt crack while you were driving it on--I've seen cracked ones come apart after starting the motor(sometimes it doesnt fail right away either!)and cause mucho damage!!. /forums/images/graemlins/crazy.gif
  5. cheyennesuper
    Nov 2, 2004
    52
    Wisconsin
    I ended up heating the gear with a torch and it pulled off.Thanks anyway guys.
