stuck tire
Discussion in 'The Garage' started by 69k5blaz, Mar 25, 2003.
  1. 69k5blaz
    69k5blaz Registered Member
    Jan 20, 2003
    35
    Lafayette, IN
    I just bought some sweet new tires and rims (35" bfg mud on baha allum rims) and a new 6" lift. Well I got the tires first and wanted to see if i could squeeze them in the wheel wells. But the original rear tire is stuck on the drum. Any suggestions for getting it off.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Did you try taking off the lugnuts? /forums/images/graemlins/rotfl.gif
    Seriously though, are the rims real rusty or anything? that's kind of odd that it's stuck on there like that. BFH on the backside of the rim might work...
  3. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    that happened on my blazer..when the wheels are on there for a long time and it gets rusty it will stick like a beotch.
  4. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    I either take a hammer to the back of the rim or if Im at work Ill hang on the lift and kick it till it comes off /forums/images/graemlins/thumb.gif
  5. paulbunyan
    paulbunyan Registered Member
    Jan 4, 2003
    15
    sexsmith ab canada
    if you hit your rim with a hammer you will wreck it. use a block of wood in between or a rubber mallet. if it is on the front you can try losining the lug nuts and turning the wheel. just make sure you dont losen them to much that you damage your wheel studs
