stud removal
Discussion in 'The Garage' started by kgblazerfive, Oct 12, 2006.
  1. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,620
    610
    Hooper, Utah 84315
    Dana 44 front rotors/hubs
    How do I get the friggin studs out???
    There's a nut on the back side but no socket will fit it.
    we tried a press, BFHammer and really bad words with no luck
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    looks like you need a thinwall 11/16 or 3/4 socket, most places wont have a thinwall but a 12pt chrome might work on it... ive never had one apart but thats what it looks like to me...
  3. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Do the threads go all the way through? If so, that is a first I have ever seen. I just did this an a very old D44. They were rusted in good. I ended up clamping a chunk of brass round stock in some vice grips and had a buddy swing a sledge hammer to pop them out.
  4. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    You mean the studs holding the rotor onto the hubs? If so, lay the rotor on the floor flat, back side down. Take a big hammer and hit the top on the stud hard, don't slip, and make sure to do it with one hit. Thats how I always do it, and if you are sure to hit to square you won't hit the threads. If so you can use the studs over again
  5. kgblazerfive
    Dec 2, 2004
    10,620
    610
    Hooper, Utah 84315
    the studs went all the way through and had a nut on the inside ended up using a air chisel to remove the nut and a BH to pound the stud out
