stud removel
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBoy truck, Dec 11, 2001.
  1. BigBoy truck
    BigBoy truck Registered Member
    Oct 17, 2001
    47
    memphis tn
    i need to remove some of the studs on the rear end i striped them by putting the wrong lug nuts on (yea i know i am an idot) but anyways how hard is it to do i have heard u have to remove the axel what all is invloled??
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Hmmmmmm.... never had to remove them but I guess you would have to remove the axle. Remove your diff cover and let all the juice drain out. Remove the center pin on the diff. There is a small (10mm on mine, so maybe 3/8) bolt holding it in place. Push the axle in (about a 1/2 " maybe) and remove the c clip and slide the axle out. Reverse the order to replace the axle! Good luck.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  3. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    If you have a LSD rear end don't forget to add posi lube. And fill out your profile, let us know a little about yourself.
    Jim
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    If this is a 6-lug axle, you can usually just remove the brake drum and rotate the axle to a spot where there's enough clearance behind the stud to drive it out. If you're running a 14-bolt full floater, then you have to remove the axle shaft and the hub assembly to get to the backside of the studs.
  5. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    Is it that simple? I've never had to do it but thats good to know! Is there room with the backing plate?
    Jim
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Yep, the backing plate is pretty far away from the axle flange. Gotta have room in there for the brake shoes. [​IMG] I've changed them without yanking out the axle shaft before. You just have to look and find a place to rotate the bad stud to so that there will be enough room behind it. (Have to clear the wheel cylinder, etc).
  7. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    That's really good to know! Damnit this site kicks ass!!
    Jim
  8. BigBoy truck
    Oct 17, 2001
    47
    memphis tn
    what about the front is it just as easy as the rear?
  9. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    The front gets a bit more challenging. You have to remove the caliper and then the hub/rotor assembly. [​IMG] Then you can drive out the studs. The studs actually hold the rotor to the hub, so they're rather long.
