Stud Remover, anyone have one?
Discussion in 'The Garage' started by sled_dog, Nov 14, 2005.
  1. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Like it? I think I need one. Trying to get the stock style studs out of my knuckles on the Dana 60 and I can't seem to do it. Thread the nuts on, jam them against each other and wrench on the lower one and they both just turn right off without budging the stud. Thinking a stud remover will be the only way it is going to happen. So again, anyone?
    I mean one like this:
    http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=SEARS&pid=00904458000
    If so, where did you get yours? I would order that one but I need it for Saturday and the shipping looks like it sucks from Sears.com so I can't chance not getting it. Seems to be something Sears stores do not stock. Damn CrapOn guy that comes to school doesn't have a truck(just some factory rep) so I can't buy it off him.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I have this Snap-on one.
    http://buy1.snapon.com/catalog/item...&group_ID=1247&store=snapon-store&dir=catalog
    This stud remover/installer works perfect everytime. You can buy just the holder and whatever size collet you need for a particular job cheap enough but i don't think you will get it in time like you said about sears. May be worth a shot though if you call Snap-on and place the order and ask for it quickly.
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I had two studs stuck in my knuckles. Got mine from NAPA for twice that price but it needed to be done that day. Put it on short breaker bar and it worked like a charm.
  4. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    I bought my kit from Mac tools it works great about 150.00
    Sears does make one of those one size fits all thingers, Last time I used it, it worked good(just not in any tight spots)
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    looks like a really nice set, I should get it but can't justify the cost for this one job. Damn...
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have an older snap-on that is similar to the craftsman one linked. the one i have has 2 wedges for different size studs.
    i love it and use it all the time. better and easier than double nutting it and vise grips.
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I just welded a nut onto each one and threaded them right out.
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah my studs are WAY too stuck for vice grips and like I said, double nut didn't work. Short of welding a nut on a stud remover is all tahts gonna get it done I think. I didn't think about tacking a nut on until just now though... hmm think I will do that and get the Craftsman one for later use.
  9. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    I have one like that... forget if its craftsman or not. In any case, for removing studs it works great. I only use it if double-nutting won't work though, mainly because the remover sometimes destroys the stud in the process.
    j
  10. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Here's a little trick that helps with stubborn studs or bolts that you can't get out. Try heating the area slightly then use beeswax and tap on the end of the stud then try to remove it once it cools down a bit. The beeswax soaks into the threads and the tapping on the end helps to jar the threads loose. Has worked many times for me in the past.
  11. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    yeah we do that when disassembling motors at school. All the A/O torches in the shop have a candle on the carts. I'd prefer not to heat my knuckles though. They are the Ford knuckles which are notoriouslly weak(at least in comparison to Chevy ones) in that exact area, so I just don't care to put heat to them.
  12. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    first off, you don't need to get them very hot, just warm enough to melt the beeswax into the threads. Also a candle is not what i mean, go to the store and find beeswax, it is 100% pure bee wax and works much better than a candle will with other things in the candle.
  13. jolane
    jolane 1/2 ton status
    May 27, 2004
    132
    I have the Craftsman stud remover, and it has worked every time a double nut wouldn't. It does marr/dig into the surface though, so I would recommend replacing the stud after using it. I wouldn't use it for installing studs either. It looks like the snap-on one will install also, but that is a lot of coin!
    Joshua
  14. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I've got the Craftsman, the very one you linked to. Worked good for me at the trans shop; haven't had a chance to use it at home (yet...). As noted already, it does have a tendency to booger-up the stud if it's really stuck.
    For the really stubborn studs in transmission cases, we'd take the torch and heat the exposed part of the stud (keeping the heat away from the case) until the top half of the exposed part was cherry. Kill the heat and let it cool for a couple minutes, then crank it out with the remover (careful, it's still HOT! Learned that one the almost-hard way...)
  15. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    Got that Craftsman one from Sears where they had a couple in stock.
