Stuff for sale: Some deliverable to the Seattle/Tacoma area
Discussion in 'Pacific Region' started by mountainexplorer, Aug 19, 2005.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    (4) 15x10 6-lug Chrome Spoke rims $80
    SM465 4spd 4x4 transmission, 10-spline $40
    10-spline NP205 T-case $125
    Misc rear drivelines... $25-$45
    Drivelines for: Longbed 1/2 ton 2wd with TH350/ 4x4 with 350/203; K5 with 208; etc
    Adapters for:
    TH350/208; 700R4/208 tall or short; 465/208. $30 each.
    Flat style T-case crossmember $5 each
    Aluminum dust covers for TH350/TH400 K-case trannys $10 each
    Factory 3-leaf '73-'87 front springs $5/pair
    4x4 steering gear box $25
    Tilt automatic steering column, 1974 or 1980, $75 each
    Factory option low back buckets out of a '77 Chevy Pickup truck, need re-upholstered, usable with off-white vinyl... not tore up much, $40/pair
    Steel bellhousing for Chevy SM465 $25 (sale pending)
    SM420 4spd 2wd truck tranny $20
    Flattop knuckles off Dana 44 front, $60/pair
    Hydroboost brake booster and lines $40
    Dana 44 and 10-bolt axleshafts, right and left inner and outer, $40/set
    6-lug front hub assemblies and rotors, $10/side
    8-lug front hub assemblies (large external hub style), no rotors, $20/side
    Complete 3/4 ton Dana 44 8-lug front, 4.09, open, new Warn locking hubs, newer balljoints, $225.
    (2) 36x12.50x15 Radial Swampers, low tread, on 15x10 6-lug Chrome mods, $75 for the pair.
    http://community.webshots.com/photo/31238809/436540654YDBjTC
    http://community.webshots.com/photo/31238809/436542203cwnVwo
    73-80 Pedal assemblies for automatic $10; for 4spd mechanical clutch $20.
    2 Light blue dash pads, in good shape, for 73-80. Not faded or cracked like most, $50 and $60
    Misc lenses, headlight buckets (73-80), stock grilles, trim pieces, gauges, etc...
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    whats wrong with the sm420 and what all is included?
  3. mountainexplorer
    Nov 14, 2001
    4,903
    It's just the tranny itself. I don't think I have a shifter for it. It's "supposed" to be in working condition, but I never drove it. Just one of my trade acquisitions.
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    no bellhousing?
    fixed or slip yoke?
  5. mountainexplorer
    Nov 14, 2001
    4,903
    Fixed rear yoke. Out of a late '60's Chevy pickup I believe. I didn't get a bellhousing with it. I'm not sure if a 465 bellhousing would bolt up or not, but it might.
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    from what I have heard is bellhousing and flywheels are different.
    i like the idea of a 7.2 to one low gear. dunno if i want to rip the willys back apart,LOL
  7. mountainexplorer
    Nov 14, 2001
    4,903
    I'll have to take another look at it when I'm up there this weekend and maybe take pics.
  8. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    on this is a flat top set up? if not what would it take to get this axel and your flat tops down to Corvallis??? ( 1 hour south of salem)
  9. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Is that NP205 a fixed or slip yoke?
    Steve---
  10. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    I'm interested in the axle truss/ skid plate for the Dana 44. PM'd you.
  11. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    you have the 2 pice style driveling out of a quad cab you say? how long are the splines on it?
  12. mountainexplorer
    Nov 14, 2001
    4,903
    The Dana 44 complete front end is does not have flattops. I can take a picture of the front end for you. The rotors were new when the balljoints were done, but it's been sitting out and there's surface rust now. I have the flattops pulled off the other housing and ready to go. I also looked closer at that SM420 and it's missing the rear yoke.
    The NP205 is a fixed rear yoke out of a 1976 truck.
    I'd rather not ship the axle truss, but maybe we can find a way to get it to you. I'll try and get pics of it so you can see if it's what you want. I believe it's an old Rhino brand axle truss.
    I'll have to go measure the splines on the drivelines.
    I'm up in Ione right now where most of the stuff is. I was able to use someone elses computer to check messages... and I should be back home to my computer late tonight. Hopefully I'll have more info for everyone who had queations by then.
  13. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    allen, also if you could snap a pic of the rear of the 420. i saw one on a jeep site with the figure 8 pattern that my 465 has. also it is only the lower two bolts that are the bellhousing problem so i if it has the same pattern i'll take it.
    now to gather up a divorced 203 and start a doubler build.
  14. Cricket
    Nov 29, 2004
    8,224
    Colorado
    Sounds good, I could probably talk Kenny into an eventual delivery.
  15. mountainexplorer
    Nov 14, 2001
    4,903
    The length of the splines is about 7.5 inches.
  16. 4xrick
    Sep 14, 2003
    1,102
    kirkland Wa
    dam i need some where about 9 or so. that may work but I am going to have to do some figuring to make sure.
  17. mountainexplorer
    Nov 14, 2001
    4,903
    I checked again. From the end of the splines to the carrier bearing is 7.5 inches. It looks like the carrier bearing is slid over the splines. I couldn't pull it off by hand... but if it's splined all the way to the other side of the carrier bearing under it, then it would be right at about 9 inches. I have like 3 of them here, one of the crew cab ones and two regular cab 2-piece drivelines with the same end only shorter overall.
  18. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    i think i'll take that front and the flat tops. just have to find my hammer and hit the piggy bank.
  19. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    sent a PM about the Steel Bellhousing
  20. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    "8-lug front hub assemblies (large external hub style), no rotors, $20/side"
    You still have these? Do they need rebuilt?
    Any 8 lug D44/10B backing plates?
