stuff for sale
Discussion in 'Complete Vehicles' started by fourwheelerjeff, Nov 19, 2006.
  1. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    i have to sell most of my stuff. i was going to ebay it, but going to post it here first and see if any of you are interested. descriptions will brief and pictures may be hard to get, but ask any questions and i will answer them.
    new prices 11-16-06
    vehicles:
    1995 chevy c2500HD with the 6.5 turbo diesel, auto, full power, extended cab, just had the upper control arm bushings replaced and the a/c serviced. 6500.00 5500.00
    1988 chevy c2500LD with 5.7, auto. there is a little rust on this on and it needs the sending unit in the gas tank replaced. 2000.00 1750.00
    1981 chevy k5 blazer rolling chassis, clean truck, d60 and 14b (4.56 out of an M1028} both have only 2700 miles on them, NEW rancho 4 inch kit with ord shackle flip in the rear, NEW braided stainless brake lines, NEW ord H.D shckles, NEW greasable bushing kit front and rear, ord box brace, clean frame no cracks or damage ever, body is fully stripped and disassembled, boxed rockers, front clip, dash cut out, this is a project and you need to be mechanically familiar with k trucks/welding and fab to put it together. 2500.00 2250.00
    1979 chevy k5 blazer with a 12 inch lift and 3/4 ton axles. i believe a 44/14 with 4.10 gears. the tires will be 39 inch mickey-t's on white spoke wheels. right now there is no carb on it or driveshafts. 350/350/203. it has a lot of rust on it. great potential for a rig with a smaller lift. 1500.00 1250.00
    1986 blazer with a 6 inch chassis lift and 3 inch body lift. does run but will need a rear axle. it currently does not have one. it also needs other parts and tlc. 1500.00 1250.00
    1988 or 89 blazer needs an engine (tbi) and the left rear quarter is crunched. the tranny and transfer have been changed out to a 350/203 combo if i remember correctly. 1000.00 750.00
    1986 M1008, project army truck. has 6 inch lift and 35 inch bfg mud's. 60/14 with 4.56's. 5000.00 4500.00
    1982 swb 4x4 truck. actually needs a lot of tlc. engine is missing. has a 350/205 combo under it and 33 radial's on rally's. someone stole the dash out of it and started taking the heater and all out of it. 750.00 500.00
    1973 k20 burb. has a non-running 350, 350/205 combo. 44/14 combo with flat tops and 4.10's. 750.00 650.00
    1987 cherokee. project lil' red. 4.0, auto, 231. 7 inches of lift, cut fenders, ford 8.8 with disc brakes, 4.56 gears, welded rear. on 36's. 3500.00 3250.00
    1988 cherokee. it has new 30 inch tires and a new 3 inch rough country lift. i was saving it for my daughter but life goes on. 4.0, auto, 231, 30/35 with 3.55's in the axles, laredo package (full power). 2500.00 2250.00
    1987 cherokee. it only moves when it is put in 4 wheel drive. i bought this and trailered it to my parents house and hooked the cables up to it and started it, seems to run real good. but i have not checked it out to see why it doesn't move. it is currently at my parents house but i will get them to send me some pics and post them up if anyone is interested. it is the 4.0, auto, 231 with a 30/35 with 3.55 gears in it. it also has some wiring problems as there are some wires wrapped around the steering column and when i touched them together the fan came on. i bought it to either fix up or use for parts, but i already have 4 others of these, so i decided to sell this one. 1000.00 800.00
    1988 cherokee 2 door model. 4.0, auto, 231. i bought this to use for parts for my other cherokees. it is rough shape with the driver's door off but laying in the back. headlights and bezels, turn signals and all is missing off of the front. and i DO NOT have the title. 600.00 500.00
    tires
    (4) 18/39.5-15 boggers mounted on 15x10 8x6.5 white spoke wheels. 2 of the tires are brand new as are 2 of the wheels. the other 2 have 90% or better mounted on white spokes that have been painted black. 1200.00
    (4) 38/14.50-15 tsl sx's 80% or better 600.00
    (4) 36/12.50-16 tsl radials 80% or better 600.00
    (4) 35/14.50-15 boggers 80% or better 500.00
    axles
    10 bolt front 8 lug, 4.10s and mini spool, big spicer external lockouts, needs one lock out. 300.00
    wheels
    (32) 16.5x9.75 8x6.5 pattern white spoke wheels new in the box. 50.00 each or 160.00 a set of 4
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    wow, thats a lot of goodies, sounds like you dont WANT to part with any of it... good luck bro...
  3. The Butcher
    The Butcher 1/2 ton status Premium Member
    May 17, 2005
    418
    39
    Texas. In a van, down by the river!
    How far away are you from Houston, Tx? Can you PM me some pics of the project army truck and the Blazer on the axles from the M1028? Thanks.
  4. blazeonchevy
    blazeonchevy 1/2 ton status
    Jan 13, 2006
    401
    san antonio tx
    pmed you.. could you also show me pics of the boggers? (the 35's)
  5. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    Could you post some pictures of the 1973 suburban.
    bigred81
  6. 96texasz
    96texasz Registered Member
    Nov 13, 2006
    28
    Wichita Falls, TX
    pm sent
  7. fourwheelerjeff
    Nov 16, 2001
    3,419
    6
  8. blazeonchevy
    Jan 13, 2006
    401
    san antonio tx
    i guess none of the tires?:confused: :dunno:
  9. 96texasz
    Nov 13, 2006
    28
    Wichita Falls, TX
    hi i am interested in both blazers you have for sale because i am looking for a solid blazer to start wheeling with i hope you can answer some of my questions and maybe give me some further insight. Also if you have pics that would be great too.
    for the 79 will it run after putting in d-shafts and a carb? how is the tread on the tires?
    for the 86 what other parts besides the axle will it need? and what size tires if any?
    for the rust on the 79 can that be cut out?
  10. fourwheelerjeff
    Nov 16, 2001
    3,419
    6
    not at this time. hopefully soon.
