Stumbling when gas pedal is depressed...?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by nau81blazer, Nov 11, 2005.
  1. nau81blazer
    nau81blazer 1/2 ton status
    Mar 6, 2004
    329
    Cincinnati, OH
    Hey Guys,
    I was driving in the truck the other day and it was doing something weird. From a stop when I would press the gas down like 1/3 of the way the truck would seem like it was about to die then started going again. I check the carb to make sure the choke wasn't stuck closed (which seems to happen w/this edelbrock) and it was fine. Have any ideas? Anything you can suggest would be greatly appreciated! Thanks,
    --Adam
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Sounds like a spark or fuel issue. Check/clean or replace the cap and rotor, plugs and wires.
    Have you changed the fuel filter.
  3. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    sounds like the accelerator pump to me.
  4. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    When did it start doing this? Right after startup or after the engine was warm? Did it just start out of the blue or has it been getting worse and worse? Automatic trans? Does it stumble when out of gear?
  5. nau81blazer
    Mar 6, 2004
    329
    Cincinnati, OH
    It just started doing it out of the blue....It only does it when the truck is in gear. Out of gear, you press the gas, it revs up like it's supposed too. In gear, if you just press the pedal a little it seems like its gonna die out, then it slowly gets more power. It does this after the truck has warmed up for about 4 min. I just changed the coil and cap last year. :confused:
    Thanks for the input so far guys,
    --Adam
  6. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    It could be a bunch of things, but some of them have already been suggested. Basically, your issues are gonna be either spark, fuel, or vacuum related, although a vacuum leak will usually show up more at idle.
    I had a similar issue once, but it only showed up once the engine was warm. It ended up being bad wires.... The fact that the symptoms only show up once the truck is warmed up leads me to believe it's spark or choke related.
    Let us know what you find out, brother.
  7. kram
    kram Registered Member
    May 29, 2005
    54
    Edison n.j.
    i have the same problem only it's a tbi.
    new dist.,coil ,wires, plugs and fuel filter helped a little.
    k&n filter and motor are 2000 miles old.
    my next guess is the egr system.
    she runs great other wise.
    any help?
    thanks.
  8. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    Q-Jet information
    I've been doing a lot of research and about have my Q-Jet rebuilt.
    link to excellent articles:
    http://www.florida4x4.com/tech/quadrajet/index.php
    especially check out the 'troubleshooting' article
    sorry to send you elsewhere, but there could be a number of issues
    Happy tuning
    1985 K30 SRW
