Stumped by brakes???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Gold Rush, Feb 8, 2002.
  1. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    Need some ideas as to what could cause brake pedal slowly going to the floor and not completely stopping a 72 Blazer. A friend of mine called me about this the other day. He has replaced the master cylinder with 3 different remanufactured ones then bought a NEW not rebuilt ACDELCO one. He put in a vacuum booster and front calipers. Then he bought a NEW AC Delco proportioning valve and put that in. He put in my 12 bolt which already had new wheel cylinders a few months prior to me taking it out. What else could be the problem?????????????? I'm thinking the only thing left is his stock rubber brake lines. Could the rubber lines be expanding internally????
    Any help would be appreciated.
    David
    <a target="_blank" href=http://www.extremeblazer.com>ExtremeBlazer</a>
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    When I went to the stainles steel brake lines up front I noticed a big diffrence in my pedal. But I wasn't going to floor first.. I am not a mech. But aren't you supposed to bleed the master cylinder before you install it.. Maybe he is not doing that..Just a thought...Dan
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    tow it down to a shop and have them powerbleed it.
    Grant
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  4. BrianK5
    BrianK5 Registered Member
    Sep 20, 2001
    58
    Omaha, Nebraska
    If the master wasn't bench bled, it could be causing this. I doubt that the lines are expanding so much that the pedal would go to the floor. If you think the lines are bad, replace those and go from there. Also make sure the shoes are adjusted out on the rear(almost no drag when you spin the drum).
    1985 K5 Blazer
  5. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    i agree have it power bled
    i just went through this problem and power bleeding is the way to go
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  6. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    While I haven't had this problem on my K5, I did have it on my 68 Camaro. My old rubber brake lines were expanding and caused the pedal to nearly drop to the floor and barely stop the car. A new set of rubber brake lines cured it. I would try bench bleeding the master cyl first or power bleed the system.
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
