stupid 14 bolt, need help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Nov 10, 2001.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    so i was all excited, hot damn, im gonna install my 14 bolt, after much work getting it under the truck, the spring perches dont line up, they're off by about 1/2-3/4 of an inch. im all mad, wat do i do? im guessing im gonna hafta reweld them into position.
    phill
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    You must have gotten a 14 bolt out of a 1 ton. They are not the same as the 3/4 ton. All you have to do is cut them of and weld them back on. Good luck
    <font color=blue>It's easier to teach a child than to fix an adult.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It's pretty common for the springs not to just drop right onto the perches. Every time I've ever installed a lift kit, or swapped an axle, I've had to wrestle the center pins into the holes on the perches. 1/2 inch is pretty close. Measure against your old axle and see if the distance between the perches isn't the same on both of the axles. It should be. A 14-bolt from a 1-ton is off by at least a couple of inches, so I think you're probably really close to having that bad boy installed! (It's heavy, ain't it?) [​IMG]
    <a target="_blank" href=http://www.angelfire.com/super/ThunderTruck>http://www.angelfire.com/super/ThunderTruck</a>
  4. Esteban86K5
    3,712
    Bakersfield, CA
    Dang, Your right Harry. For some reason I read 2 3/4 inches off. Which is about what the one tons perches are at. But 1/2 to 3/4 inches is nothing. Get that ole prybar out. Or loosen the spring bolts a little so it moves enough to get them installed. Your O.K.!!! Get out there and put that pig in.[​IMG]
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Oddly enough I was just outside measuring mine...I got 40 1/4" between the spring pads as near as I could figure. If it's narrower than that it may have been a one ton diff.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  6. shupach
    Dec 28, 2000
    648
    Dallas, TX
    god i luv this forum, aight tomorrow the crowbar is coming out.
    phill
  7. Esteban86K5
    3,712
    Bakersfield, CA
    It's only what 6pm right now? Get out there and put the pig in now. Come on you can do it. You will sleep better tonite knowing that it's in.[​IMG]
  8. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    I usually just pull on the axle while pushing against the spring with my feet until it lines up. [​IMG] I've found it's easier if you have the spring resting lightly against the perch, this way when the pin lines up, it will be forced into the hole and stay there. If you leave a big gap, it will keep trying to come apart while you tighten the nuts on the u-bolt.
  9. shupach
    Dec 28, 2000
    648
    Dallas, TX
    i have this thing called a gf, and while we did "work" on the blazer this morning, i think im going to go out w/ her tonite. sorry, but tomrrow is another day(probably do it when i get back at like 12).
    phill
  10. shupach
    Dec 28, 2000
    648
    Dallas, TX
    hey wat about 1/2- 3/4 inches off on each side.
    phill
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Did you measure your old axle? Sounds like it should still be ok to pull it in.
    About the "working" with your girl friend. First time my Father saw my (soon to be ex) wife, we were rebuilding the 455 in my 66 GTO in my Fathers shop. He wasn't supposed to be there that day so we were "goofing off" a little. Anyway, he shows up and she had clear (greasy) hand prints on the back of her jeans and a few other choice places. She had planted a few on me too. He never let me live it down! [​IMG]
    Russ
    85 K30 CUCV, 350 TBI, TH400, 205, D60/C14, 4.56 Locked
    Some day: 4" lift, 44" tires, massive cutting, shorter wb and rear overhang.
  12. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Ah!!! A g/f. No good I tell ya. They don't wanna help you work on the truck. Don't wanna hear every mod you've done and what you've planned. Don't care where in the heck you've been with the truck. Haha, then why in the hell do we all want one?!
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  13. shupach
    Dec 28, 2000
    648
    Dallas, TX
    ok so wat if like when i line up one of the centerpins, the other is off by like 2 inches? is that good bad or evil?
    thanks,
    phill
  14. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Then the perches will need to be moved...[​IMG]
    Rene
  15. Esteban86K5
    3,712
    Bakersfield, CA
    Cut and weld!!! Cut and Weld!!![​IMG][​IMG]
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Yep, sounds like you got a 1 ton axle. 1/2" is no big deal, 1" is pushing it, 2" is too much. Time to do a little cutting and welding. Look at the article on this site that shows how to make some heavy perches out of 2" square tubing.
    Russ
  17. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    You might also want to check and see if the shock mounts on the 14 bolt are located on the correct side to mount your shocks. If they're on the opposite side I think you have a 14 bolt that came out of a one ton.
    Ric
    <font color=red>Wheel hard or go home.</font color=red>
    <a target="_blank" href=http://community.webshots.com/user/bowtie1ton>MY K5</a>
  18. shupach
    Dec 28, 2000
    648
    Dallas, TX
    @#$**O&amp;@O*&amp;$#@O*&amp;!!!!!!!!!!!!!!!!!! yes the shock mounts are flipped.
    phill
  19. BOWTIE
    Dec 28, 2000
    2,018
    Sorry to hear about that... Looks like it's time to bring out the torch and welder.
    Ric
  20. shupach
    Dec 28, 2000
    648
    Dallas, TX
    i got another question while im at it, do u recommend ubolts or the square upside ubolt design thinger, the axle came w/ plates for the square ubolts.
    phill
