STUPID 14bff disk brake question
Discussion in 'The Garage' started by 85mudblazin, Aug 23, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Which way does the mounting bracket go, lean to the rear or lean to the front??
    -CHris
  2. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    Lean to the rear.
  3. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Thanks ya sir /forums/images/graemlins/thumb.gif
  4. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
  5. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I have my SKY brackets leaning towards the front, which puts the bleeder directly on top. I don't know about the DIY brackets though
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I have the az-kicken brackets and hose kits. That make a difference??
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i did mine to the rear and the hose bracket to the front, works good, blead easy
  8. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    You can lean them forward or rear ward depending on whether you use the left on the right and so on. I don't see it making a difference swapping sides. I prefer them in the back leaning rear that is. It keeps them more protected and keeps the hoses behind the axle housing. Look at the front I believe they are the same in the front. Leaning rear.
