stupid balljoint question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Jan 25, 2001.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I'm going to do these, but it may be a while, but...do I have to take the steering arm off to change them?
    90K5
  2. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    No they will clear the steering arm, but just barely. If it does by chance hit then you should use a die grinder to clearance just enought to get it off. The steering arm is too difficult to remove. Also make sure you buy Moog ball joints and not Napa joints. With the Napa joints you will have to pull the axle to grease the top ball joint with Moog you will not. In Denver Car quest carries Moog so if you have a car quest in your area then that would be the place to buy.
    I thought I was wrong once,
    but I was mistaken
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Thanks Butch...I bought the balljoints a while ago, but they are Moog, got them at O'Reilly. I do need to change the steering arm though, maybe this will be a good time to do it...
    90K5
  4. bigjim321
    bigjim321 Registered Member
    Dec 12, 2000
    15
    Dallas/Tx
    yes i agree the moog parts are more maintance friendly. I dont know if the style has changed but my 76 has to have a special socket to tighten the upper joint (so the knuckle moves at 25 lbs) as it shows in the service book. i didn't do this the first time and it wasn't long before i was replacing them again.
    Lack of mud makes a man mean!!
  5. Butch
    Apr 26, 2000
    1,338
    Austin, TX
    Hey Big Jim. For that special tool, you just have to proficient at using a hammer and punch to set that pre load. I am either too cheap or too lazy to buy that tool, so I end up using a punch to turn the insert with and set the proper load.
    but I was mistaken
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    What is the preload, and how do you set it?
    90K5
  7. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Actually you can buy a cheap 6 point 3/4" socket 1/2" drive and grind it down to fit the adjusting sleeve and it works great. To adjust the preload, tighten the upper nut hand tight, then torque the lower joint nut to specified torque. Then remove the upper nut and torque the adjusting sleeve to it's specified torque setting. Reinstall the top nut and torque and you should be home.
  8. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Adjusting sleeve is 50ft lbs. You can buy the tool from napa for about 18.00. I have the part # if needed. I would change steering arm at that time also.
