Stupid Breaks!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JunkYardCrawler, Apr 10, 2001.
  1. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    My retarded brakes wont bleed. it feels like there is an air poket in them and i can't get it out. its just messing with me man. now you got breaks and then now you don't. and some one keeps taking my brake fluid.
  2. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    Subject reads "breaks" I thought this was about broken axles, ring and pinion, or broke driveshafts. You know trail carnage.
    79 Blazer 6"lift 35's locked/4:56 <A target="_blank" HREF=http://www.keith.coloradok5.com>http://www.keith.coloradok5.com</A>
  3. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Go pick up a do dad called a Mity Vac at your parts store, should suck that air right on out. Are you doing anything to your propoting valve when you're doing this because you're suppossed to hold some button if I remeber.
  4. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    no i'm not. i don't even know where the propoting valve is. just pumping and bleeding. worked befor i pulled the diffs. man i have nothing but problems with these stupid breaks.
