Stupid clock on the puter, help...
Discussion in 'The Lounge' started by chevyfumes, Jun 13, 2002.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    The clock on my puter is an hour ahead and when I fix it, it lasts for about 3-4 hours then alla the sudden it's an hour off again... WTF!!!! /forums/images/icons/mad.gif /forums/images/icons/mad.gif /forums/images/icons/mad.gif
  2. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color="blue">Mine's the same way ! What the hell ! It sucks when you're watching an e-bay auction ! </font color>
  3. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Ya! Mine is always 10 minutes off! /forums/images/icons/mad.gif
  4. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Are you guys on networks? It might be syncing to a network server that's off.
    We have certain machines here at work on a Netware server that's in the wrong time zone, and sets every machine connected to it to the wrong time zone. We can't change it without risk of corrupting the tree or something like that (I'm not a netware guy)...
  5. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    I'm talking about on my home puter
  6. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Here's the first thing I found that looks relative on MS technet. Gotta go work now, if I find more I'll post 'em.
    P.S. A lot of Win98 stuff will work in ME.
    CAUSE
    This last symptom listed in this article can occur for either of the following
    reasons:
    - Advanced Power Management (APM) settings are enabled in the BIOS.
    - You configure your computer to use third-party anti-virus, system utility,
    and screen saver programs.
    RESOLUTION
    To resolve the issue for the last symptom listed in this article, use one of the
    following methods:
    APM Settings
    Disable APM in the BIOS and configure Windows to manage APM. For information
    about how to disable APM in the BIOS, please contact the manufacturer of your
    computer.
    To configure Windows to manage APM:
    1. Click Start, point to Settings, and then click Control Panel.
    2. Double-click Power Management, select the settings you want for APM, and then
    click OK.
    Disable Third-Party Programs and Utilities
    Disable the following types of programs and utilities:
    - Anti-virus
    - Screen savers
    - System utilities
    Clean Boot
    Configure your computer to start with a clean boot. For additional information
    about configuring a clean boot, click the article numbers below to view the
    articles in the Microsoft Knowledge Base:
    Q192926 How to Perform Clean-Boot Troubleshooting for Windows 98
    Q243039 How to Perform a Clean Boot in Windows 95
    STATUS
    Microsoft has confirmed this to be a problem in the Microsoft products that are
    listed at the beginning of this article.
    MORE INFORMATION
    If your computer loses time, use the Date/Time tool to set the correct time:
    2. Double-click Date/Time.
    3. On the Date &amp; Time tab, configure the correct time, and then click OK.
    To determine if the time loss is a result of a weak computer battery:
    1. Click Start, point to Programs, and then click MS-DOS Prompt.
    2. At the command prompt, type "time" (without the quotation marks), and then
    press ENTER.
    3. Compare this time with the time that is reported by the clock on the taskbar.
    4. Type "exit" (without the quotation marks), and then press ENTER.
    If the computer's time and the time on the clock are different, the computer's
    battery may be too weak to keep accurate time, and it should be replaced. For
    information about how to replace the battery, refer to the documentation
    included with your computer.
    NOTE: This problem does not affect the clock in your computer's CMOS.
