Stupid dash lights went out...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Mar 10, 2002.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    They just decided they didnt want to light up anymore...
    I checked the fuse... it's fine....
    The dash lights, and the heater lights dont work... blinkers still work, and the high beam indicator still works... ????
    WTF?
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    tailights still work?
  3. replace the headlight switch. the one in your dash that you pull to turn the lights on. LMC has em.
  4. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    i had this problem a while back...had to do with the headlight switch connection being loose...check that before you buy a new switch...i ended up buying a new switch and it still did it with the new one...when i figured out the problem i eventually solved it with a zip tie...
    Later
  5. BigTex
    BigTex 1/2 ton status
    Dec 27, 2000
    974
    South Texas
    Also check the connection behind the circuit board. It might be loose.
