Stupid fake lug nuts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Panther, Mar 7, 2002.
  1. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    Hey guys. First of all, here's a tip. Always loosen the lug nuts before you jack the truck up.
    OK, here's the question. The lug nuts on my truck (90, stock) all seem to be these fake lug nuts with thin metal caps on them. The actual, completely metal lug nut is about half as long, has a hole down the center, and is a hair smaller in size. Once I popped the metal cap off, I had to use an 18MM socket to get it off (I don't know if that's right though since I'm having trouble getting the nut outta the socket now /forums/images/icons/wink.gif ).
    Can I just replace these with real, solid lug nuts or are they on there for a (good) reason?
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Just replace them w/ real ones...they are that way from the facrory because it is cheeper.
  3. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    they're there to look "pretty"...just go buy some cheap steel lug nuts.
  4. Panther
    Aug 31, 2000
    845
    South Jersey
    Thanks guys
    Exxxxcellent [tenting fingers].
    I'll pick some up before I finish my hubs (which is why I have it up on stands).
