Stupid fuel line??
Discussion in 'The Garage' started by BLZN4FN, Mar 4, 2006.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Ok I'm trying to Help out Firefighter183 w/ his K5
    Its a 1989 350 fuel injected.
    His return fuel line from the throttle body to the frame rail is leaking fuel. Can we cut the bad spot out and replace with rubber hose? I know the feed line has high psi going into the throttle body but how much psi in the return side to the tank?
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    i dont see why not. i believe that system only runs at 20 psi or less. put a small flare on the cut ends of the line, and double clamp it, should be good.
  3. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    Quick way VS right way...
    I've rubber hosed RETURN lines on TBI vehicles to get someone moving again in an emergency..just be sure to use fuel injection hose and not "regular" carbed fuel line hose..double clamps are a good idea too,as Beater K20 said..
    I would not trust rubber hose on the high pressure side,period..
    A better and more permanent fix is to splice in a new length of tubing using compression fittings ,they can be found at parts stores,home deopt or Lowe's,etc..or use a flaring tool, and line nuts and couplings,just like on a brake line..:crazy: ..
  4. azblazer
    azblazer 1/2 ton status Premium Member
    Jul 20, 2003
    695
    15
    Grand Junction, Co.
    Yes you can. Tbi pressure is 9-13 psi. The lines from gm at the good guy price run $48.75 a piece. Problem is if do not use the factory clamp on the backside of the passenger side head it will not last more than a week if you are lucky. So go to turbocity.com and order there fittings. They are 10 bux a pop and then you can go to azone or checker and buy fuel injection hose...a heavier sidewall version of the normal 5/16-3/8 fuel line...works great.
    Doug Wright
  5. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Another thing to try...at Transwest Freightliner we have fittings for A/C lines that you can cut the metal part that's broken off, it will crimp the metal and you can run stratoflex line. On the other end, just use the same fitting to crimp to the metal line.
    I agree, spill lines don't run much pressure if any, and the actual pressure side only goes up to about 13 as AZ said. I've seen rubber hose and clamps work on low side of AC systems..and they can get to 70PSI.
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    On the return side you can use low pressure fuel line. I am running low PSI line on the return with my TPI and it is fine. The return pressure is only around 5 psi which standard line can handle fine. The sending line should be FI line but the return can be regular.
    Harley
  7. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    The pick-a-part out on Peoria has several TBI trucks, probably get a line for 5 or 6 bucks.
  8. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    which side is the return side? i cracked mine right at the fitting....WAT DO I DO???
  9. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    I'm having some custom braided lines made by a race shop here in Arvada. Total cost: $160.00. They will warranty them for 3 years. Mileage unlimited. I'm going to run them to the passender side of the engine compartment, then down past the AC and along the frame rail. Easier access and nothing hot or moving to rub or burn them.
  10. BLZN4FN
    Dec 19, 2000
    1,720
    Englewood Colorado
    Cool will you up for this weekend's run?
  11. azblazer
    Jul 20, 2003
    695
    15
    Grand Junction, Co.
    89gmcsub...what do you do for transwest? I worked for them for a little over 3 years in junction before getting a job in the oilfields...
    Worked for Sundance Truck Center/Freightliner Az. Ltd./Cunningham Commercial Vehicles for 7 years..and a 9 month break at the KW dealer with Basil T.
    DW
  12. firefighter184
    Apr 5, 2003
    2,763
    The Barrio
    Planning on it, but I might have to go to CA for work. If I stay here, I should be ready rock...
