stupid hub problem with pic
Discussion in 'The Garage' started by bobalob, Mar 28, 2006.
  1. bobalob
    bobalob 1/2 ton status
    Jul 20, 2005
    157
    Everson, Washington
    Blew drivers side u-joint and the ears of inner and outer shafts this weekend. Pulled it out and replaced with new stuff but when attempting to put warn hub back in a tweaked snap ring that holds it together fell out (don't know how to properly explain, so hopefully the pic explains it). The question is how/where do i get a new replacement doohickey(this one is deformed).:confused:
  2. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I get mine at a plumbing supply store. Plumbing is what they specialize in but they have a little of everything. If you have no luck with that, try any shop that makes hydraulic hoses and has the associated fittings. I've seen some in truck shops as well.
  3. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    NAPA has a good slection of snap rings.
