stupid internet explorer
Discussion in 'The Lounge' started by unick, Apr 13, 2004.
  1. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Whenever I try to download pics off the site(well any site for that matter) IE tryes to save them as a BMP. Y does it do this and how can I fix it?
    lmk
    NIck
  2. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    http://support.microsoft.com/default.aspx?scid=kb;en-us;810978&Product=winsvr2003
    To paste the text:
    SUMMARY
    When you save an image in Microsoft Internet Explorer, the image is saved by default as a bitmap (.bmp). You do not have the option to save the image by using an extension other than .bmp. You experience this behavior even when the image uses a different format (such as .gif or .jpeg).
    For example, when you right-click an image on a Web page, and then click Save Picture As, the file name that appears in the File name box is Untitled, and the file type that appears in the Save as type box is Bitmap (*.bmp).
    CAUSE
    This behavior may occur if a damaged program file (for example, an ActiveX or Java object) is downloaded to the SystemRoot\Downloaded Program Files folder on your hard disk.
    RESOLUTION
    To troubleshoot and resolve this behavior, empty the contents of the Temporary Internet Files folder, and then delete the files in the Downloaded Program Files folder that are listed as either Unknown or Damaged. To do so:
    Start Internet Explorer (if it is not already started).
    Empty the contents of the Temporary Internet Files folder. To do so:
    On the Tools menu, click Internet Options.
    Click the General tab.
    Under Temporary Internet files, click Delete Files.
    When you are prompted to delete all temporary Internet files, click OK.
    In the Downloaded Program Files folder on your hard disk, remove the files that are listed as either Unknown or Damaged. To do so:
    Under Temporary Internet files, click Settings.
    Click View Objects.
    The list of program files that are downloaded to the SystemRoot\Downloaded Program Files folder on your hard disk appears in the Downloaded Program Files window.
    In the Status column, note the files that are listed as either Unknown or Damaged. Remove these files. To do so, right-click the file, and then click Remove.
    When you are prompted to confirm the removal, click Yes.
    Close the Downloaded Program Files window, and then click OK two times.
    Save an image in Internet Explorer to test and determine if the issue is resolved.
    If the issue continues to occur after you remove all downloaded program files that are listed as Unknown or Damaged, try removing the other downloaded program files that are on the list.
    Note: The next time that you need one of the files that you removed from the Downloaded Program Files folder, you will receive a prompt to download the file to your hard disk in Internet Explorer
  3. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    . /forums/images/graemlins/thinking.gif
  4. unick
    Aug 16, 2003
    4,286
    COOL thanx newyorkin it worked. You're a computer
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I never have liked IE. I run Netscape, it's much more user friendly then IE in my opinion anyways. Download Netscape
  6. unick
    Aug 16, 2003
    4,286
    i used to run netscape I hated IE but now I like IE.
  7. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    Ie faster than nutscrape
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]I don't know about dial up users, but Netscape is fast for me, but then again I use a Cable ISP instead of dial up.
  9. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Mozilla faster than both.
  10. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]I thought that Netscape 7.2 and Mozilla are basicly the same browser.
  11. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    They are, but Mozilla, and more specificly Firefox, have much less BS so they run faster and more efficiently. Netscape is still good though. Anything beats IE.
  12. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Command line (text only) is faster than both.
    /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/whistling.gif
  13. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    They are, but Mozilla, and more specificly Firefox, have much less BS so they run faster and more efficiently. Netscape is still good though. Everything beats IE.
    [/ QUOTE ]Fixed it for ya. /forums/images/graemlins/thumb.gif
  14. tecton
    Dec 1, 2002
    1,553
    WV
    i run firefox
    if i could just get msn to use firefox to open msn mail it would be sweet
  15. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Yeah, I use Links when I'm in Linux. /forums/images/graemlins/thumb.gif
  16. tecton
    Dec 1, 2002
    1,553
    WV
    lynx is really neat
    i remember back in the day, before the internet was outside of colleges for the most part, searching for legos and power rangers, i was a wee tike then
  17. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Ah yes, I remember dialing in via a blazing fast 2400 baud modem and using Lynx running on top of VMS via a VT100 terminal. /forums/images/graemlins/yikes.gif /forums/images/graemlins/thumb.gif Things have certianly come a LONG way in the last 10 years or so!
  18. Goober
    Apr 26, 2002
    2,222
    I still have my 300 baud modem sitting in a box somewhere. /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif but these newfangled phones don't sit in the cradle correctly so I can't use it. /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
    That sucker is almost as big as my Laptop, and a few pounds heavier. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
