Stupid P/S steering pump...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fjleiter, Sep 11, 2004.
  1. fjleiter
    fjleiter 1/2 ton status
    Feb 13, 2004
    278
    Palmyra, NY
    Finally have time to yank the motor and get ready to put the new one in and am stuck...
    How Do I get the power steering pump off the engine? Looks like all the bolts holding it on are either blocked by the brackets or the pulley! About ready to /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif the dang thing off if I didn't need to reuse it.
    (the old V-belt systems were so much easier....)
    (1990 K5 Blazer/ 350 gas)
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You would be correct. The pulley does block the bolts. You'll have to pull it off with the correct puller to remove the pump.
  3. Ruthven13
    Ruthven13 1/2 ton status
    Mar 10, 2003
    664
    Fair Verona
    Right again. I just did this and had to go to the auto parts store and get a p/s pulley puller. A regular jaw puller will only bend the pulley. With that it comes right off /forums/images/graemlins/thumb.gif
  4. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    832
    Pinckney, MI
    when my pump went I stared at the thing for like an hour, then went to the autoparts store and they were having a sale on PS pulley puller. Kinda weird huh
  5. fjleiter
    Feb 13, 2004
    278
    Palmyra, NY
    Turns out I had a puller in my toolbox! (think most people call it a crowbar though). No time to rent a real puller and little patience so I tweaked it enough to sneak a wrench in. Figure I will replace the pulley when I re-assemble. (in a time crunch, need the crankshaft out of this motor for my new motor)
