stupid question #1
Discussion in 'The Garage' started by 58 apache, Sep 1, 2006.
  1. 58 apache
    58 apache 1/2 ton status
    Aug 26, 2006
    377
    clarksville,Va home of the body bag
    i want to get a bds suspension lift. just got a 14ff do i get a lift for a 1/2 ton k5 still or will i have to get stuff specific to the axles i use?:confused: :confused:
  2. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
  3. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    If you order a lift for the K5 you will get ubolts for the 1/2 axles. (I found this out the hard way.) Make sure they know if is for a K5 but you have a 14 bolt in the rear. They should include the correct ubolts.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Suburbans and trucks use the same 14FF, just order a lift for a 3/4ton burb or truck. They all use the same length front springs.
  5. 58 apache
    Aug 26, 2006
    377
    how do i measure the springs i have now to determine if they are stock size?
  6. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    You don't have to. Look at the attachments to the frame. If there are rivets it's stock. Any change of the length they will have been replaced by bolts. Then it's the measurement from center to center of the spring eyes.
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    bds makes good stuff. i had bds rear spings and still have bds fronts. very happy with them.
  8. 58 apache
    Aug 26, 2006
    377
    they arnt stock mounts in the rear cuz most of the frame is still the 58 we cut off the front clip of a k5 and welded it to the front of the 58 frame. that way we retained the body mounts etc. we jost bolted rear mounts to the frame. so i measure straight accross from eye to eye? what is stock spring length?
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    for the rear springs, either 52" or 56" for a 14ff
