Stupid Question of the day. Re: D70U
Discussion in 'The Garage' started by mofugly13, Mar 18, 2004.
  1. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Loking at my NEW (to me) D70U on the floor of my shop, how do I remove the drums? Do I have to pull the axles to do this? It looks as if the hub and drum are one piece?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    If it's a ford they should slide off IIRC.
    For GM's you've got to un-do the spindle nuts like a front axle hub assembly removal.
    Welcome to the world of full floating axles /forums/images/graemlins/smile.gif
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes unbolt the eight axle flange end bolts and pull the shafts and then go for the big nuts in there yep
    dont need to pull diff cover to remove shafts and drums on the FF axles
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    On my Dodge 70 ya gotta pull the shafts and the hub and drum come off together.But the hub and drum are not one piece.If you drive out the wheel studs the two pieces come apart /forums/images/graemlins/grin.gif
    Whats your 70 out of?What gears ya gonna run?
    Oh yea,Ya gotta remove the spindle nuts after ya pull the shaft to get everything off.My spindle nuts are 2.5".
  5. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    I pulled it off an '85 Ford F-250 Diesel. I donno for sure yet what gears I'm gonna run. My next set of tires will be 35". Probably 4.11 since this is my daily driver/road tripper. After I posted the first time I went downstairs and pulled an axle. I saw that it has to come apart like a d44 hub, but with a drum instead of a disc.
    Looks like I'm gonna need to do a disc conversion. /forums/images/graemlins/whistling.gif
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    At which time you'll find that those wheel bearings are still required. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  7. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    What does the "U" part of D70U mean? I know the first part is Dana 70, but whats the "U". Thanks /forums/images/graemlins/waytogo.gif
  8. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    who makes the disk conversion for the D70?
    Thanks.
  9. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Ya sure its a Dana 70?Im only asking cuz I almost pulled what I thought was for sure a 70U out of a E350 but it turned out to be a Dana 61 (worthless).
    All the research I did said it was a 70U.So I grabbed a buddy and went back to the yard but before we pulled it he suggested we pull a shaft to make sure it was 1.5,35 spline.It wasnt,it was a little under 1.25,30 spline.
    I was sad /forums/images/graemlins/frown.gif
  10. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    There is a post in the Ford section on Pirate where a guy did it.
    He used Dana 60 caliper brackets and 10 bolt/44 calipers.He used Ford rotors and put the bracket on the back side of the flange.I think he said a GM 10bolt/44 rotor could be used by mounting the bracket to the outside of the flange.
    I looked easy /forums/images/graemlins/grin.gif
  11. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
  12. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I did a quick search and found this quote and alot of other info.This is in regaurds to a diesel truck also,
    "The higher GVW package necessitated the use of the full float rear axle, which was a Dana 61 in F-250s and lower GVW F-350s to about February ’85 production and the 10.25 inch ring gear Ford Sterling after."
    Aint sayin ya dont know what ya got,just want ya to be sure before ya spend and time or $$$ on it /forums/images/graemlins/thumb.gif
    Chris
  13. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    The first thing I did when I saw this mofo at the yard was pull a shaft and count splines. When I counted 35 is when I got excited. I pulled a metal tag that was bolted under some cover bolts and came here to ask about it. I posted the numbers and Tweetysaurus came back with this. U2slow posted this link. Everything looked good, so I went and got it! It looks like it has not been abused, and regularly serviced. The oil was very clean when I drained it.
    Thanks for the link, FRIZZLEFRY, looks like it shouldn't be too much of a problem. /forums/images/graemlins/waytogo.gif
  14. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
  15. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Cool deal /forums/images/graemlins/waytogo.gif
    WAY cool that the tag was still on the cover.The 70 I ended up with had no tag and no BOM number on the axle tubes.I got help from some guys over at Pirate as to a guess on a year and aplication from numbers on the ring gear.You will have a much easier time getting parts than I did /forums/images/graemlins/grin.gif
    Chris
  16. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Im running 16" rims off of a mid 90s Ford.I have 3.5" wide drums though.Wonder if it would still work?
    Thanks for the link /forums/images/graemlins/grin.gif
  17. u2slow
    May 9, 2001
    2,217
    BC Canada
  18. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    Re: MOFUGLY13
    Thanks a bunch, bro. /forums/images/graemlins/thumb.gif
    Matt
    IBEW 617, San Mateo, Ca
  19. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    All dana 70U's i have seen (both in real life and on the intarweb) have had totally smooth centersections, no lumps or ridges or fins. The rockcrawlers on PBB love the things, no need to shave the axle from stock unless you are desperate for ground clearance.
  20. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    FWIW, a D44 or 10 bolt 8-lug rotor will not work. Not on my D70U anyway. The hole in the center of the rotor is too small to fit over the hub. Need a 5.400" hole, the 3/4 ton rotors have a 5.130" hole. I am thinking that I could put the hub on the lathe and cut it down .270" but that would take a funky setup to be sure that the hub is running true to the bearing race axis so the cut is concentric to the spindle axis. I don't really wanna have to mod the hubs if I don't have to. I toyed with the idea of opening up the center hole on the 3/4 ton rotors, but the swing on my lathe is only 11" and I would need a swing of at least 12.5". This would also require setting up so that the rotor was turning true to the spindle axis. I'm gonna create a post to see if someone can measure the center hole on a D60 rotor for me.
