stupid question on PTO's
Discussion in 'The Garage' started by MUD JUNKIE, Dec 1, 2003.
  1. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    stupid question on PTO\'s
    I know jack shiot on hydro steering and PTO's so go easy on me.
    if you had a PTO unit mounted to your 205 case,and it runs on hydro fluid,why cant you run this with a cylinder for hydro steering??
  2. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    Re: stupid question on PTO\'s
    The pto output will only spin as fast as the other outputs on the t case so if you arent moving niether is the pto(unless you are in neutral with the t-case and you have an auto trans.)That ought to start it off any way. /forums/images/graemlins/smirk.gif
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    however, in neutral on an SM465 PTOs still work i believe, as long as the clutch is engaged.
  4. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    correct.
    there is no reason you cant run a PTO on the 205 to run the hydro steering. it is an eventual plan of mine once i go rear steer. but that is a long way off.
    yuo will have to keep it in gear with any tranny if you run it off of the t-case. for front steering it would be a trail rig only thing.
    Grant
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    I think it would suck to loose power steering everytime you push in the clutch /forums/images/graemlins/eek.gif
