Stupid question...sorry.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by walt88, Jan 28, 2001.
  1. walt88
    walt88 1/2 ton status
    May 24, 2000
    430
    Monmouth County, NJ
    What does a flotation size mean? Does that mean it will float in the water if it is filled or someting?? sorry
    Keep the shiny side up, and the greasy side down.
  2. CBLAZER81
    CBLAZER81 1/2 ton status
    Mar 3, 2000
    281
    Milliken,COLORADO
    The only stupid questions are the ones that you don't ask,brother.Knowledge has to come from somewhere.....To answer your question,it has to do with the relationship between your tire and the ground.
    Basicly the wider the tire is the more "floatation" you'll have on any given surface.There is also a factor of tire pressure that you have to add into the equasion......
    I'm kinda drunk so I'm sure somebody else can explain it alot better....
    I did use a couple of big words though if that counts for anything...hehehehe
    Chuck
    81 Blazer
    <font color=blue>does anyone have another F#@d that I can park on?</font color=blue>[​IMG]
    <font color=red><A target="_blank" HREF=http://www.chucks81k5.coloradok5.com>http://www.chucks81k5.coloradok5.com</A></font color=red>
  3. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    CBLAZER81 covered it pretty well(even drunk!). If you look at sand rails, they have wide tires mounted on 12"-15" wide rims. This allows the tire to stay on top of the sand, or "float". Mud tires, for example, dig so they are not a flotation type tire. Hope this helps to explain.
    <A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
    Protect the land FOR the people
    Not FROM the people
