stupid question
Discussion in 'The Garage' started by lunchbox, Jul 11, 2006.
  1. lunchbox
    lunchbox 1/2 ton status
    Jan 22, 2006
    309
    novato,california
    im trying to install a throttle body spacer (easy right?) i cant seem to find the fuse for the fuel pump can sombody tell me where it is?
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Any particular year, make and model of vehicle?
    Do you need the additional height of the spacer for linkage clearance (oddball custom induction setups make it a necessity on occasion), or just to take advantage of amazing increases in both fuel economy and power, all at an unbelieveably low price for the promised benefits?
  3. 3rdshiftdesign
    3rdshiftdesign 1/2 ton status
    Feb 6, 2005
    259
    Bucks County, PA
    Wow, they really give you that much of a fuel increase and power, for so cheap? :haha:
  4. lunchbox
    Jan 22, 2006
    309
    novato,california
    its an 87 tbi 305
  5. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Why would you need to find the fuel pump fuse?
    Leaving the key off should be sufficient. Unless you need to bleed off pressure, which there isnt much, just slowly open the lines. Or disconnect the fuel pump relay on the passenger side firewall and crank it over.
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    The ECM feeds the fuel pump. Pull the ECM fuse.
  7. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    the TBI trucks bleed the pressure off on their own, just crack the lines, shouldn't spray
