stupid question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dbltapp, Aug 17, 2001.
  1. dbltapp
    dbltapp 1/2 ton status
    Apr 25, 2001
    133
    Maine, but moving again.
    what all would i need to add or change when i go up to 6" lift? i have 2 1/2" now, i think i know but i just want to double check with you folks!
    89 SUBURBAN, 1/2 TON, 350 TBI,21/2 LIFT W/33'S
  2. J.R.
    J.R. Guest
    if you are buyiong a complete lift kit, it will come with all the parts you will need. springs,bolts,pitman arm,brake lines, brackets, etc.. a lot of the time its better to spend the money for a good kit and get everything then try to piece it together yourself.
    BIG BLOCK MAN
    "MORE POWER"!!
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    That isn't necessarily the case...dbltap, make *sure* that your kit comes with all the stuff J.R. mentioned, and also shocks. The shocks you have now would fit while the suspension is a rest, but once you flex, you may break one. Also, they probably arent valved to work with the taller lift springs.
    Lift It, Lock It, LIVE IT!!!
  4. dbltapp
    Apr 25, 2001
    133
    right, but what about brake lines, e-brake cable, breather lines, drive shaft and do i need to shimthe rear axle?
  5. LittleJimmy
    LittleJimmy 1/2 ton status
    Feb 16, 2001
    220
    Channahon IL
    With that lift you will have do everything those guy's said. Plus you will definetly need new drive shafts. Custom style with cv I would say. But that is me......
  6. flcpl4fn
    flcpl4fn 1/2 ton status
    Jan 9, 2001
    194
    Florida
    before you go and get a new driveshaft, try the old one and see how it fits. i put on an 8" likt one my jimmy and the old shaft worked great. i haven't had any problems with it since i lifted it over a year ago. don
    '85 Jimmy in Jax, Fl
