Stupid ring and pinion question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by alec78, Jun 21, 2005.
  1. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    So the stupid question for the day is: Is rust on a tooth of a ring rear make the gear set unusable?
  2. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    wow, thats wierd that only one tooth is rusty that much and the rest look good. i dont really know, i doubt it but it would bug me personally to know that theres rust in there at all. could be a good excuse to go to lower gears. if you want to.
  3. dyeager535
    26,980
    that'll wear off in a heartbeat. I say run it. :)
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Sure thats rust?? looks like some old caked on oil to me :)
  5. Bigg R
    Bigg R Registered Member
    Feb 21, 2005
    34
    Martinsville,Indiana
    If there are no pits in the metal, I say run it!! If you want to feel better about running it, take a piece of Scotchbrite to it and clean with brake cleaner!!!
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Like everyone said, depends how bad it is.
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    clean it and run it.
    Grant
  8. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    I picked up a set of used gears several years ago. They were cleaned, but had pits from rust. I took them to a shop and to a friend who was a mechanic, and both said not to use them if they had pits.
    Eric M.
  9. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yep, we replace gearsets if they have rust on them, there no good to run. Like Larry says "thats like wiping before you poop it dont make any sense."
  10. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    When I worked at TransAxle, we re-used rusty gearsets all the time (tranny gears and R&P's). We would disassemble and sandblast the gears, then inspect the tooth faces in the contact area. If the pitting was bad, we'd scrap it, but if there were just minor pits and not many of them, we'd buff the pitted teeth with a 3M Roloc buffing pad to remove any sharp edges and burrs.
    This was all heavy truck stuff though...
