stupid stupid stupid stupid squeek
Discussion in 'The Garage' started by tecton, May 3, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    its coming from inside the dash
    passenger side
    perhaps behind the glovebox
    truck looks like a million bucks but sounds like a beater
    should i drown it in a pool of wd-40?
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    It's usually the plastic rubbing on something. Try tightening all the screws. If your going to lube it, don't use WD-40. Use something thatwill last longer like lithium grease.
  3. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Try removing the glove compartment, and drive it around. If it does not squeak, then you know it is something to do with the glove compartment. If it does squeak, then with the glove compartment removed it might help you to pinpoint the squeak.
  4. camok10
    camok10 1/2 ton status
    May 1, 2004
    288
    Tucson, AZ.
    Alpine deck, JL 6x9 3 ways, silk dome tweeters, ALpine amp and RF 10" sub. I hear no squeeks or rattles /forums/images/graemlins/thumb.gif. haha
