Stupid Tach Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Cusm, Feb 16, 2001.
  1. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    I came across this on ebay, will this work in an '82 or is this not worth the time? It has a fuel gauge on the tach. Here is the description: <font color=blue>YOU ARE BIDDING ON A FACTORY TACH FROM A 5 TON TRUCK. APPEARS TO BE IN VERY GOOD CONDITION. COMES WITH WIRING HARNESS. THIS TACH WILL FIT NORMAL 1/2 CLUSTERS WITH MINIMUM MODIFICATION. THE TACH HAS IT'S OWN HARNESS THAT RAN TO A JUNCTION BLOCK. ALSO INCLUDED IS THE VACUUM GUAGE THAT GOES IN PLACE OF THE CLOCK-BOTTOM LEFT OF GUAGE CLUSTER. ALL THAT NEEDS IS A VACUUM LINE TO THE MANIFOLD.</font color=blue>
  2. dyeager535
    26,982
    191
    Probably just like all the other ones, it depends on what year its from. Older gauge assemblies are not just drop ins..the wiring changed. Also, these truck ones that I have seen have the fuel gauge under the tach. I didn't like it.
    Dorian
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Wy would a tach need a vacuum line hooked up to it?
    Become one with nature............Then marinate it..
  4. FastEddy
    FastEddy 1/2 ton status
    Feb 3, 2001
    182
    southeast manitoba, canada
    the tach used in the larger trucks probably will not be what you want...they only go up to about 5000 rpm...these tall deck 366 and 427 engines used in the large trucks are built for torque and are not a high reving engine...the vacume line probably has something to do with the govener on these engines....also watch out for these tach's from the large trucks...some were cable drive, not electric...just my 2 cents...if you really want the factory tach look, and can't find a factory tach, try looking into a tach out of a mid 80's pontiac grand prix...they are fairly common, and look to be the same size....could be made to work i think with a little enginering....I've had one sitting in the shed now for a couple years just for that purpose....but will i ever get around too it....?
  5. dyeager535
    26,982
    191
    Get one out of a Camaro. Almost all, if not all, had the tach. You remove all the fuel gauge stuff from your large fuel gauge, affix the Camaro tach display to the top of the truck fuel gauge, and attach the electricals for the tach to the backside. I noticed he did some soldering on the printed circuit board, but that was to relocate the fuel gauge to the clocks location. I didn't make the one in my truck, my dad did, but the numerals are almost identical, and you can not tell that it is not factory, except the 4wd and choke light cut outs had to be made or enlarged. Not only that, it goes higher than the truck tachs. Tachs out of different GM makes/models varied (that is, the RPM range was different) depending on engine and designed usage. Only problem is finding one of the small fuel gauges, but you may be able to from LMC.
    Dorian
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    I did that conversion - got the entire cluster from Zach Carlson (remember him?). Simple changeover.
    Regarding the vacuum line - it is not for the tach, is was used in those beastly 366 or 427 motors for keeping an eye on things when braking, etc. I have had one in my truck for years, just another way of keeping an eye on things. Useful for assisting you keep the gas mileage up..........if you watch it and how hard you push the skinny pedal, that is!
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  7. 89 Blazzer
    89 Blazzer Registered Member
    Aug 9, 2000
    29
    dyeager535, I am interested in doing this set-up. Do you have any pics of what it looks like? Also any additional info about the the modifications and soldering would be appreciated.
  8. dyeager535
    26,982
    191
    I don't have any pics yet, but I could probably take some. Could just photograph the back of the circuit board too. I'll see if I remember tonight. All you have to do though is get the wires that USED to go to the large fuel gauge, over to the new location for the smaller ones. Not much to it, even though I didn't do the work.
    Dorian
  9. Cusm
    Cusm 1/2 ton status
    Feb 25, 2000
    360
    OK
    Do you know approx what year of Camero? I saw an '85 gauges and there is no way ti would work or look good, it was the funky one where the speedo had the the back of the needle for the K/H
