stupid thermostat question
Discussion in 'The Garage' started by elwhitey, Mar 31, 2005.
  1. elwhitey
    elwhitey Registered Member
    Mar 21, 2005
    42
    Chandler, Az.
    I am trying to swap out my thermastat, expecting to just take a couple of minutes on my '74 Jimmy and I can't seem to get the shield over the alternator off. The bolt that pivots off of the water pump hits the pulley, and with it still on that I can't get it off of the bolt on the them. housing. I shouldn't have to take the pump off should I?
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    No, you don't have to remove the waterpump. You also shouldn't have to remove any bolts/brackets other than the two bolts that hold the thermostat housing on. Unless your alternator bracket uses one of those bolts as a moutning point.
  3. elwhitey
    Mar 21, 2005
    42
    Chandler, Az.
    Thats the problem. The bracket from the alt. goes over the left housing bolt.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you will have to remove the bolt for the alternator bracket on the water pump and loosen the upper bolt for the alternator to get it to move enough to get the housing off.
  5. elwhitey
    Mar 21, 2005
    42
    Chandler, Az.
    That is the problem I am running into, the bolt backs up into the pulley on the pump. If I could get it past the pulley it wouldn't be a problem, but that is what is killing me.
  6. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    then take the bolt out of the alternator and force it out of the way. otherwords, you need to loosen both the alternator and powersteering pump, AC pump if you have AC, and the fan to get the pulley off to get the bolt out.
