stupid toolbar on IE
Discussion in 'The Lounge' started by unick, May 6, 2004.
  1. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Ok some website installed a tool bar on my IE. How can I get it off??
    Lmk
    Nick
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Spybot Search & Destroy and/or Adaware /forums/images/graemlins/thumb.gif both available at Download.com Make sure to run the auto updates for them before running the scan, that will catch a lot more crap. /forums/images/graemlins/waytogo.gif
  3. unick
    Aug 16, 2003
    4,286
    adaware doesntr work for [darn]!!!
  4. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    /forums/images/graemlins/eek.gif What is the name of the toolbar? Is it MySearch or iSearch?
  5. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Download Mozilla(browser); IE blows.... /forums/images/graemlins/grin.gif
  6. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    If it's the Lycos thing, you probably now have a dozen or so unknown .exe's installed and processes running.
    Use adaware, it's the easiest method, but make sure you download and install the update, and make sure you're using build number 181, earlier versions don't detect much of the modern crap that's out there.
    After each scan, scan again, using custom settings to scan within archives and favorites. Scan over and over again until the scan comes up with nothing.
    I suspect these things are being deployed by sh!tty and unscrupulous advertising companies that place the ads in popup windows. They either exploit Windows security holes, or prompt you to install something (most people unconsciously click "yes" when prompted). 3 machines at work got it shortly after they each visited the same website, which had just changed it's popups.
    Once one gets in, it seems to download and install dozens more.
    Also, if you have a firewall, block "advertising.com" and "Zedo.com". When I got hit with some bitchy little spyware/popup POS, I blocked those domains and saw a TON of hits attempted on them. F***kers should be hacked and shutdown, they're ruining the internet for corporate users that will soon end up getting access turned off because of the risks they cause. If there were grounds to sue them, we should get a class action suit going to close thier operation down.
    When I used Mozilla it was a dog...
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Adaware works good for me also. You pretty much have to do what newyorkin says.You must keep ad-aware updated it is usless without updates. The newer spyware can be difficult to remove once in your computer.
    I also scan with trendmicro.com
    Click on "Free Scan" It finds stuff my Norton anti virus misses. It is espically good at picking out trogan horse and back door virusses that spyware companys use to install their stuff on your computer. You have to be a little patient with it. It takes a little time to load and start working.
    Also what newyorkin said about using firewalls is right on. I use the one That comes with my DSL service to block anything that gets thru to my comp. If a pop up makes it thru my seceurty settings. I block its domain name(s) with the firewall and never see it again.
  8. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    I had one once...forgot what it was, but when I typed in a bad web address i got a dotcom.com thingie I had to download somthing called shredder to get rid of it.
