Stupid tranny question
Discussion in 'The Garage' started by stockk5, May 1, 2006.
  1. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    This is a really stupid question but i put my tranny pan back on once w/ gasket and some permatex and it leaked.. so i took it off.. then i just used the gasket it self worked great for about 500miles.. then 2days ago my pan started leaking a ton again , theres a 2ft puddle under my truck after about 1hr, all the bolts are tight too, what am i doing wrong or could cause this?? it is leaking from the back of the pan of the 700r. thanks for any help guys :confused: :doah: :doah:
  2. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    youre not overtightenign them are you ?
    it will split the gasket at the bolt holes if you do
    or you probably already know that
    maybe the pan is warped
    its very possible
    also is the pan flat and ok at all the bolt holes and not raised around them ?
    if so then its time ot flatten it with a ball peen hammer, or get another pan
    rtv the cork gasket to the pan first, let that setup and then put it on the tranny dry, tighten bolts up snug but not so much as to press gasket out from between the pan and the case, gasket tack in a can on a brush is also good to attach the gasket to the pan and would technically be safer than rtv, just in case any of the rtv broke free inside the tranny and got into anything it shouldnt
    if it leaks then something else is bad
    good luck
  3. bigkennye
    bigkennye Registered Member
    Nov 8, 2005
    45
    virginia
    i would never use any rtv gasket sealer on a trans pan, the tranny fluid eats the gasket sealer and it causes particles to accumulate, and then what may happen is the valve body clogs and you blow a seal, that is what happened to mine, aaamco did the rebuild and because the truck sat for awhile, the warranty expired and i am screwed.
