stupid valve cover gasket
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shupach, Oct 7, 2001.
  1. shupach
    shupach 1/2 ton status
    Dec 28, 2000
    648
    Dallas, TX
    i find it its the cause of a major oil leak(surprise, surprise). Whats really boggled my mind is the fact that i've replaced that gasket like 3x!!! i even torqued down the valve cover bolts to like 7 lbfts? and torqued them in the special pattern. is there any other way to make the leakin end? Right now im using rubber gaskets for it, i thought they might work a bit better than cork, but i could be wrong, please, help me.
    phill
  2. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Rubber works good. Big thing to look for is a straight surface on the valve cover and to use some of the spacers to spread out the force of the bolt. The stamped steel covers warp pretty easy and it's the only reason I go with the cast aluminum covers. I use a little of the 3M weather strip sealer to hold my gaskets in place when I put them on. If I use rubber I don't use any gasket sealer, just wipe everything down with some alcohol before I put it together.
    Smitty
  3. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    why did chev decide that it didnt need to machine the VC mounting surface? ? ?
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Probably got a set of warped covers - might need to use a set of cork gaskets with lots of RTV, Like Permatex's Ultra Black. Also take a fairly coarse flat file and scuff a crosshatch onto the valve cover mounting surfaces to "grab" the gasket a little better.
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    The left coverr on my 73 used to leak like crazy.
    I used my high lift for a flat surface and a hammer and straightened the rails. then I applied a thin coat of RTV and let it set up.
    then I used a rubber gasget and spreaders and have been bone dry eversince.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  6. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    I'm not a big fan of 'go fast' chrome and aluminum under the hood. I made an exception with my Valve covers. I found an old set of Edelbrock finned aluminum valve covers for cheap and said good-bye to leaks from my valve covers. The nice flat and rigid gasket surface allows for a much better seal.
    Rene
  7. shupach
    Dec 28, 2000
    648
    Dallas, TX
    i have edelbrock chrome valve covers and i have little spacers from the old valve covers. last time i used some rtv my gasket exploded and leaked everywhere. But ill replace 'em one more time.
    phill
  8. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Only 7 ft lbs? I thought the proper torque for valve covers was 25 or so. 7 doesnt seem more than just finger tight.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  9. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I'd have a hard time putting 7 ft/lbs on one of the later model "not quite as tough as tin foil" valve covers. Older ones I would say about 20-25 though.
  10. shupach
    Dec 28, 2000
    648
    Dallas, TX
    so like 7 lbs or 25? i've got the new edelbrock valve covers? i heard if i torque it down too much i kill my gaskets.
    phill
  11. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    My rule of thumb is to tighten them just using an extension by hand, and then add 1/4 turn with a ratchet. I'm not sure what exactly I'd be torquing them to like that, but I've never had one leak yet using that method.
  12. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Pugs is on the money........just a wee bit more than hand tight is lots for valve covers.
    <font color=blue> WE WILL NEVER SURRENDER<font color=blue>
  13. shupach
    Dec 28, 2000
    648
    Dallas, TX
    i will follow in your ways pugs
    phill
  14. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    You have passed the final test, and you are now ready Grasshopper, to take on the valve covers[​IMG].
  15. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    If uyou have to use rtv you have a problem. I have chrome edelbrock valve cover and use VICTOR-REINZ valve cover gaskest.They are cork-ruber but they are 5/16" thick. Twice as thick as regular gaskets. If I remember right the part # is VC38110HTC. Haven't had a leak in over 2 years. I also run t-bolt holddowns with spreaders and I just go just past finger tight.
    78-K5 4"Lift 35"Tires 400SB TH350 NP205
    73 Vega 350SB TH350
  16. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    That way the silly-cone had something to stick to.. LOL
    Like to go sloppin' 'round in da mud in a rapid fashion....=)
  17. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    REALLY? I didn't know the chrome would make the truck go faster.
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  18. Smitty
    Sep 1, 2000
    999
    Crestview, FL
    RTV won't stick to a lot of the rubber gaskets. That's why I just use a dab of 3-M weather strip sealer to hold them in place while I bolt them down. Not too sure of the torque but I use a flexible 1/4" extension that's made out of some spring stock. I think it makes it impossible to over-torque the bolts since it starts to break away with a little tension. Good luck since some of the newer trucks really make getting to the covers a real pain.
    Smitty
  19. TXBIGFISH
    TXBIGFISH 1/2 ton status
    Oct 2, 2001
    297
    Sachse TX
    You might want to try and find the rubber valve cover gaskets with a spring in it, they are re-usable, I've had a set for a while and no leaks. They are more expensive but worth it! The aluminum vc and spreaders are on the money as well.
    &lt;*)))&gt;&lt;
    81" GMC Jimmy.............stock for now!
    I see a 6 inch lift in the near future!
  20. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    You just told me your problem, RUBBER, cork does alot better job. I had the same problem you did when I bought my edelbrock aluminum valve covers. Rubber gasket never seem to want to seat or stick worth a darn. Just buy a seat of fel-pro blue strip cork gaskets and use some RTV or weatherstrip adhesive to secure to your covers and I think you will quite pleased with the results, not to mention no more headaches.
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
