Stupid ?
Discussion in 'The Garage' started by bear76, Feb 13, 2006.
  1. bear76
    bear76 1/2 ton status
    Oct 16, 2005
    1,065
    here
    I will be changing my brakes soon, first k5 brake job. The question, where should I jack from. My cherokee, I used to jack it at the axels, but this thing is heavy. Are the axels strong enough or should I buy/use a taller jack and stands and use the frame?
    Thanks.
  2. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    the "proper" way is to put it on jackstands...
    that being said, i always lifted mine by the axle..
  3. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
    yeah just put the jack under the axle.. jack it up.. slide a jackstand down and repeat as needed.
  4. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Jack by the axle. Hell, you can jack on the pumpkin and throw in two jackstands. No need to jack twice.
  5. goldwing2000
    goldwing2000 Guest
    He has to get it off the ground, first. Pretty sure he's asking for jack points to lift with before putting the stands under.
    K5 axles are plenty strong enough to support the weight of the vehicle for lifting from the center. You'll have to do one side at a time in the front, though. Not because of weight, just that it doesn't go up even if you put the jack under the diff. My jack isn't tall enough to lift the diff high enough to get the left wheel off the ground. :wink1:
  6. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,957
    249
    Released from Pueblo, told I belong in Southpark
    Yep jacking on the axles is fine. Definately use jackstands. I jack up the front using the pumpkin and since it is off center only the passenger side goes up and then I put a jackstand under it and I use a floor jack so I put my floor jack ontop of a scrap of 4 X 4 that I have and jack up the driver's side, then put the jack stand under that side. I like to do both sides at once. Less handling of the tools and seems to go quicker for me.
  7. bear76
    Oct 16, 2005
    1,065
    here
    Thanks! After messing with this beast I should be able to bench press my old jeep!:D
  8. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    yeah that should be no problem. my little wife bench presses jeeps all day. i think she maxed out at about 7 tho...
    then there's me:
    just add an attractive face and a bigger set of underwear to cover the "region" and that's an exact replica of my manliness. :haha::puke:
  9. goldwing2000
    goldwing2000 Guest
    :yikes:
    There's probably enough friction between those thighs to start a forest fire.
  10. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ahhhh! tengo un fuego en mis pantalones!
  11. bear76
    Oct 16, 2005
    1,065
    here
    Ahhh! Meine Hosen Sind Auf Feuer!!!
  12. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i'm out of foreign languages. maybe someone can post up with a canadian translation.
  13. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    There's probably enough friction between those thighs to start a forest fire., eh
