stuttering feel on tight slow turns
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Mar 17, 2001.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    when i turn the wheel hard left or right and i am going slow, forward or back, the truck feels like it is stuttering sort of. i have 33/ 12.5 tires and positraction in the rear. would either of these give this feel. it just sort of worries me, but i hope it is nothing. if you have any ideas let me know.
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Is it like the wheel is stuttering while you are turning it (the wheel)? Cause mine does that and I can't figure out why.
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    If your truck is still full time the "stutter" is basically normal.
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
  4. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    mkay....what if it's part time?
  5. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    if it feels like its stuttering WHILE your turning,your p/s pump may be weak.try it at idle,thenspeed up the motor and try,if the stutter goes away it may be the pump.the lugs on my hawgs used to catch on my springs at full turn.scared the life outta me 1st time it did it!i thought it was comin apart.
    pure insanity
  6. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    oh wait i forgot you have posi!!it could be the rear diff tryin to lock bcuz of the difference in wheel speed in a turn.you just dont feel it at higher speed lesser turns.
    pureinsanity
  7. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Loose ps pump belt, loose brakets. Mine did this and the bottom bracket was missing.
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Make sure that you aren't holding the steering wheel against the internal pump stops. When it won't turn any further, back off an inch or two. Otherwise your pump is working really hard against full pressure.
  9. jcg
    jcg 1/2 ton status
    Mar 19, 2000
    660
    Rochester, NY
    Yeah, it's most likely the posi catching and trying to make the truck plow into the turn. My lockright does it if I try to turn sharp and I'm going too fast, the front end starts to shudder as it plows. Scares the hell outta people walking by, especially when the locker slips and then catches again... makes that nice loud bang that seems to use the brake drums to amplify it. The things we do for better performance off-road...
    Joe
    RIT Mini-Baja http://www.rit.edu/~bajawww
    Team Mudnuts http://www.mudnuts.org
  10. 88MudBeast
    88MudBeast Registered Member
    Nov 8, 2000
    67
    Dallas, TX
    mine only does it in 4WD.
    Big Jake
    Drive it like you stole it.
  11. dyeager535
    26,979
    I would be changing the fluid in teh rear diff. Could have been changed, and no posi diff lube added. That could be posi chatter. As well, if it is a gov-lok, it may be locked up all the time, mine was. Mine wasn't as bad at low speeds as it was high..sounds to me like posi chatter.
    Dorian
