sub $1500 plasma cutters?
Discussion in 'The Garage' started by jjlaughner, Aug 24, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Hobart Plasma Cutter, AirForce™ 250A with Built-In Compressor $999
    Lincoln Electric Plasma Cutter, Pro-Cut 25 $1299
    Hobart Plasma Cutter, AirForce™ 400 (115v 20amp) $1499
    any others?
    link a pic and name then I'll do poll next week
    Would like to stay around $1000-1200, can be 110v-220v (stuff you can have at home)
    has to cut 1/8-1/4" severs 3/8", larger is ok
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Go for one of the hobarts. /forums/images/graemlins/thumb.gif
  3. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I've got a ESAB 550 Handy Plasma. I like it.
  4. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    ESAB 550 Plasmarc Plasma Cutter manually cuts 1/2 inch and severs 5/8 inch - powerful cutting performance.
    Output 35 amps @ 40% duty cycle, Input 208/230 vac 1ph. 50/60 Hz, 29/27 amps, external air needed - $1500
  5. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Handy Plasmarc 125 Cutting Package has a built-in air supply
    115v, cuts 1/8" /forums/images/graemlins/tongue.gif -$730
  6. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Miller Plasma Cutters
    Spectrum Thunder 115 V, 60Hz
    Spectrum® Thunder boasts a built-in piston-driven air compressor giving it an "out of the box, ready to cut" attitude. This economical unit is capable of a maximum cut up to 1/4 in steel. -$990
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Spectrum 375 Cutmate
    Solid state design and Miller's reliable technology pack a ton of performance into the portable, 49 pound Spectrum 375 CutMate. This versatile power source adapts to the shop or work site by operating on either 115 or 230 volt AC power. This machine can cut 1/2 inch mild steel with a stand off, and can drag cut 3/8 inch mild steel
    -$1300
    ****dual power rating
    Sever: 5/8 in (16mm)….. Sever: 1/2 in (13mm)
    Quality: 1/2 in (13mm) ….. Quality: 3/8 in (10mm)
    Rated: 3/8 in (10mm)….. Rated: 5/16 in (8mm)
    1/16 in Stand off Cutting….. Drag Cutting
  8. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    bump /forums/images/graemlins/ears.gif
  9. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    -$1300
    That's my machine right there!
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I would get the one that can cut the thickest that you can afford, you will be happy you did if you ever have to cut something really fine that is thick.
    My .02 /forums/images/graemlins/thumb.gif
    -Chris
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    really now! why dont you send it my way for a couple weeks and let me try it out! /forums/images/graemlins/waytogo.gif
  12. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
  13. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    how thick do you think you'll need to cut? Don't buy something that will cut 1" mild steel if you will never need to. /forums/images/graemlins/waytogo.gif
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    When I did the research before buying mine, the HT380 (Hypertherm) was the best bang for the buck in my target requirements. Easy to find reasonable cost consumables and a great rep too. It can easily be had for under $1000, and I paid around $900 new (shipped) IIRC.
    As for built in air, I would advise to stay away from that, it compromises the machine quite a bit and the cost is ridiculous for "built in air". Those things are only good if you MUST go into the field with it frequently where compressed air is not available. If you use it in the shop, like most of us do, the built in air is wasted completely. And even when you DO use the built in air, it compromises the cut quality and size capabilities due to marginal pressure/flow. Most of this is hear-say repeated along with published specs, but given the amount of air mine likes to consume when cutting, I gotta think that this is true. In any case, even if it was 1:1, why pay that much for dedicated air on the cutter when you can use your shop air and be more certain to get the rated capacity? Something else to think of; if the dedicated compressor ever has troubles, you can bet it's more expensive to repair and you loose the use of the cutter while the compressor is down.
  15. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Agree with you Dog - word /forums/images/graemlins/tongue.gif
    haven't bought one yet either but I was leaning towards the same Hypotherm model /forums/images/graemlins/cool.gif
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think every guy's dream is to have a plasma cutter.
    Having a welder and nothing but a grinder and sawzall to cut steel with sucks. /forums/images/graemlins/rotfl.gif
  17. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Unless your a guy without a welder.... then it would be cool
    I use to think, man I'll use a torch for everything!
    Now I hate to lug the thing outside and use tanks of gas to cut things. Takes forever to warm up, then the cuts aren't always the greatest, then you have the *POP* when you get to close or have clogged up nozzles! /forums/images/graemlins/doah.gif
    I definalty want a built in air setup just the for the simple fact i dont want to have to wheel my air compressor over to the wall to plug it in or route the thick cable across the garage to run the air compressor at the same time I'm trying to use the plasma cutter. We have older wiring in the garage and using both at the same time would be harsh.
    Thats why I'm leaning toward the Miller right now, the one that has dual power setups for 110v for my current garage and 220v for the future shop!
  18. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    1/8" all the time, 3/16" tube alot and probley 1/4" and 3/8" on occation, anything more than that and severing would be fine.
  19. sponsoredbydad
    sponsoredbydad Dune Slaying Sand Junkie Premium Member GMOTM Winner
    Mar 12, 2004
    2,334
    405
    Dana Point "So Cal" "The sue me state"
    thanks for all the research I agree about the torch thing but that is all I got right now this info will help me in to the wonderful world of clean and fast cutting /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif my 69
  20. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Don't forget, the compressor is still drawing extra juice. Just because it's inside the same box is not going to cut the amount of power required to run the plaz and move a certain amount of air. But it is going to guarantee that you have to pull ALL that power across a single circuit. At least a real compressor has some capacity so it doesn't run ALL the time (just most of the time) and it can run on a different circuit to reduce the load on any single circuit.
    Not sure what all your particulars that go into this decision might be, but I urge you to look into this carefully. I was unable to find any truly good feedback on the self contained units except for hauling them into "the field" like at a junk yard, mobile welding/repair, that type of stuff. Good luck in your decision and look at the trade-offs carefully...
