sub box with convertible???
Discussion in 'Audio' started by yellowk5, Sep 12, 2002.
  1. yellowk5
    yellowk5 Registered Member
    Jul 24, 2002
    11
    ihave an 89 with a soft top. i have one 12 inch kicker and an 800 watt amp. What box will produce the loudest/nicest bass with a soft top/top down??? also does the pstioning matter if the top is off??? thanx fellas
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    With a soft-top, I would fire them at the tail gate. You need a hard surface for the (signal, note, or what ever it's called) to bounce off, or so I've been told. Try verious postioning to see what sounds the best to you. I would say as long as it sounds good to you, the rest doesn't matter.
  3. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Z3 is correct 99% of the time the relex coming from the rear is going to improve db by about 3db.
  4. TIGHTWORK82 K5
    TIGHTWORK82 K5 1/2 ton status
    Oct 21, 2001
    140
    orlando , florida
    make it a sealed box, I dont think a ported application will work without the top on. nothing fancy just a 2 ft sq box maybe 2.5 tops /forums/images/icons/wink.gif
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Air space for each sub depends on the subs themselves. Some subs require more air space then others do. I plan on useing 15" MMATS Juggernauts. Each one of those require a min. of 4.5 cubic feet in a sealed box. But I'm goinng with 5.0 cubic feet per sub for best sound quality. Other subs can use smaller cubic feet. Go by what the manufatures recomend.
  6. TIGHTWORK82 K5
    Oct 21, 2001
    140
    orlando , florida
    here here!
  7. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Huh?....... /forums/images/icons/confused.gif
    Sealed vs. Ported is a discussion all by itself, but there is no reason to select a sealed enclosure for a convertible over a ported one.
    In fact, a ported enclosure will typically outperform a sealed one by about +3dB in terms of absolute output level. In a convertible, that is welcome news! /forums/images/icons/smile.gif
    I currently run two 1.0 cu/ft ported boxes in my convertible K5, with a 10" sub in each. They are PLENTY loud with the top off, and REDICULOUSLY loud with the top on. During the winter months, I typically turn down the "input sensitivity" on the subwoofer amp so they don't play as loud. Even with a "Sub-Bass Controller" on the dash, it's just TOO much bass.
    Sorry I don't have pics of the whole stereo in the Gallery anymore. It would probably help you to see how the boxes were hidden in the side panels, and how I stuffed all those amps and speakers into every available nook and cranny!!! /forums/images/icons/grin.gif
  8. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Greg72 has the same feeling as I do, sealed and ported are just two choices. Each has a + and a -. The manufacture give recommendations, but you have the last word. Due to the fact that it's yours....A friend of mine had a jeep with 4-12's that was ported between the seats and on the subs were facing the side fo the jeep and firing into box that was open by the front doors. It was load. Nice deep bass that hit hard.
  9. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    you might think about doing a Slot Load box. It is like a Band_pass box, but for more area. I was thinking about doing this. I would have a harder time till you about this then some of there other guy would.
