sub fuel tank into p/u
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 3car, Jan 15, 2002.
  1. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    does anyone know if you can put a suburban fuel tank into a lwb p/u?
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Well, I'm betting I can! When I do my flatbed, Im going to bolt one in vetween the frame rails in the space behind the cab and the crossmember closest to the cab. Its a bog square ans wide as the frame rails. I just thin youd have to bolt or weld up a few supports, strap it in, hook up the lines, the sender wires, fab up a little filler hose to wherever the filler door is and done.
    I'd also like to know about any gas tank swapping info you guys have.
    1978 K20 - 355ci, np205, th400, D44, 14F, 7" of Lift, 36 x 14.5 TSL Radial
