Sub leaning
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fireinthehole, Dec 28, 2002.
    I noticed that my Sub is leaning a little to the left rear side. Not alot, but enough that I noticed. The lift was just installed last March, all parts were new, rough country springs all the way around, and new shocks too. I replaced all the body bushings last Dec with poly ones.
    Any ideas? I'm thinking either a bad shock or spring.
    Mat
  1. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Check for a cracked or over-settled spring on that side... the shock shouldn't make it lean... just bouncy on that side! /forums/images/graemlins/wink.gif Good luck finding the fix!
    -Dan
  2. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    my stock rear springs are making my suburban lean to the drivers side too. i don't know what it is. /forums/images/graemlins/confused.gif
  3. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    Glad to know I am not the only left-lean Suburban!
    I haven't really delved into it yet, but first up are new eye bushings and shackles. It needs these things anyway. Body mounts are good, thankfully...
    I did notice something strange on my truck...the left rear tire leans in at the top slightly and is not totally perpendicular to the ground, while the right side is. I haven't jacked it up yet to see if the bearings are smoked. What a fun job that will be if they are...
    /forums/images/graemlins/burb.gif
  4. dyeager535
    26,980
    You can (if you want to have fun) swap springs from side to side, and see if the problem changes sides. I did that, and figured out it was the opposite front spring that was really causing the problem with my trucks lean.
    No way on the shocks, they don't support the weight of the vehicle, thats all spring.
  5. I called rough country today, and they told me to swap springs to make sure. I really dont want to do it, but I guess I have to if I want them replaced. What about the rear shackles, could they cause it to lean. My fronts are ORD, so I know those are ok.
  6. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    I know that when I was at a spring shop, the owner was telling me that on tow trucks they will make the springs slightly stiffer on the left side, because of the driver. I wasn't really listening to him because I was trying to read what miss november liked to do in her spare time. I dunno why he said tow trucks specifically, but I am not calling you fat either.
  7. I'm not fat, just big boned! /forums/images/graemlins/thumb.gif No, really I have no idea why its leaning. I'm sure its the spring(s), but i'm not swapping them out to see. Its to cold and nasty and I have to work outside.
  8. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    This is a classic desease with leaf spring suspensions.
    I have yet to see a truck that has had the springs for more than 6 years without that symptom.
    I guess it's a combination of driver weight (any weight, as opposed to no driver), engine torque, and steering arm location.
    All contribute to more pressure on that side so it gets worked harder and settles faster. All springs settle after a while, and the more you work them the faster they sag.
    I would rotate them just like I do my tires. /forums/images/graemlins/thumb.gif
