sub or blazer gas tank in a pickup
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Dec 26, 2001.
    ok, wierd question but follow along with me. my 76 pickup has only one tank on the pass. side and runs dry fast. i thought instead of doing another sadle tank on the other side i would use a blazer or sub tank in back and be able to have both fill spouts on the same side. well? sound duable? mounting it seems to be the only obstical. the rest could be plumbed useing regular chevy dual tank parts.
    <font color=blue> Experience enables you to recognize a mistake when you make it again.
    </font color=blue>
  1. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    the filler neck cover that goes inside the blazer fits the pickup box perfect
    I havent tried the frame mounts yet
    you could cut the filler section from a blazer and graft it to the bed side
  2. not too worried on looks. have you seen those chrome looking aftermarket ones? i've seen them on 67-72 trucks that have added tanks to replace the one behind the seat. i don't know where to find them though.
    </font color=blue>
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
  4. yes, exactly what i was thinking! just trying to figure out how to get the straps to work. might have to fab something there.
    </font color=blue>
  5. michaelm
    Feb 2, 2001
    872
    any idea if the frame crossmembers swap onto the pickup frame?
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you could use plumbers tape[​IMG] take like 4 or 5 strands and bolt them to the bed then rais the tank up and bolt the other end to the bed[​IMG] do this on both sides and you should be fine
    wheeling videoshttp://community.webshots.com/user/ssmith6333
  7. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    I dont know about the plumbers tape thing kinda hokieI would look into fabbing up a steel craddle to bolt the tank to the frame may cost a little and take awhilebut youd be better off in the long run?
    1982 K10 Silverado. [​IMG] 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
  8. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Please, PLEASE don't do a chrome one!!!!!!!! I can't stand those!!!!!
    There is like an oversized 50 gallon tank you can get for a ford truck that mounds underneath the rear of the bed. Maybe you can get that and have a huge tank in the rear. If you're gonna go thru the trouble, might as well have an awsome capasity! If you wheel, make sure you build a skid plate for it.
    <font color=blue>What part of my brilliance do you not understand?</font color=blue>
    <a target="_blank" href=http://www.bluefox.tv/~lara>My Wonderful Site</a>
  9. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    I added a 31 gal to my 72 blazer. you can probably use the same mounting set up that I used. check out my tank pictures in the member rides. I also have a 21 gal from my 71 in the forsale section.
    ARQ.
    My Pics
