Sub positioning
Discussion in 'Audio' started by Oblin Goblin, Sep 11, 2002.
  1. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    How important is the position of a subwoofer for sound quality? I know bass travels pretty well though a car so would it make much of a difference mounting the sub in the very back of a blazer in/next to the side panel as opposed to mounting it up closer to the driver, in the center console for example? Also how important is symmetry when mounting a sub? Would having one in each side panel sound better than one big one on one side?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've found that putting your sub(s) in the rear sounds best for me. I like to run high power systems myself. The subs I run require more air space then up front would premitt. I personally like to fire my subs upward (facing the roof). I will be building one big box taking up all the space behind the rear seat to the tailgate, and from side to side, from floor to even with top of rear seat. Rear seat will be raised 4 inchs, amp rack under rear seat. Completely dynomating inside, and new carpet. Replacing side panels, and insulating /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif Well, thats the plans, now I just need the funds. /forums/images/icons/wink.gif /forums/images/icons/tongue.gif /forums/images/icons/wink.gif
  3. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Unless you want to get into imaging the direction is not of major importance. But you should have the sub firing toward a hard surface and reflecting before it reaches the driver.
  4. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    These guys basically nailed it.....the wavelengths of bass notes are WAY longer than the dimensions inside your vehicle. The concerns about "standing waves" or "modal cancellations" that the home audio/home theater guys worry about, don't apply here.
    Build 'em where they fit, and make the box STRONG and airtight (unless it's a ported design of course! /forums/images/icons/grin.gif )
    The final bits will be messing around with crossover points and slopes, and trying to blend it seamlessly with the rest of the speakers in the system.
