Subs gone bad?
Discussion in 'Audio' started by tecton, May 25, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    dual 10" subs in a 4 port box...if i set them right side up nothing covering the holes...it sounds like there is no pressure in the box...no bass
    if i take something and cover up two port holes (a 6x9 box fits perfecly) i get really deep bass out of it
    they used to work fine...dont know what happend to them
  2. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    is the amp still working ? may have a bad amp also. check that first.
  3. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    The speakers are probably wired out-of-phase with each other..... that would definitely cause the problem you describe.
  4. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    he does mention that they were working before, so i don't think wiring would be a problem unless he messed with it.
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    In my experience....it's the information NOT given by the poster that often leads to the solution. /forums/images/graemlins/laugh.gif
    /forums/images/graemlins/thumb.gif
  6. tecton
    Dec 1, 2002
    1,553
    WV
    lol
    i rewired it last night...cut off the ends and stripped new wire for it...still doing it
    it seems like its just one of them...i change the balance from L to R and it gets better/worse....prob need to open the box and look at the wiring, mabye something metal got in there or something to that effect
  7. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Throw an ohmmeter on each one before too much longer.....
    A burnt voicecoil will have close to 0 ohms (shorted) and that can explain a lot.
    You can also use the "battery trick" to make sure that the speakers are TRULY wired in-phase with each other. The cone moves OUT when power is applied and the wiring is correct.
