Suburban 14FF
Discussion in 'The Garage' started by rlhenry, Apr 29, 2006.
  1. rlhenry
    rlhenry Registered Member
    Mar 6, 2002
    93
    Morenci, AZ
    Does anybody know what years GM put 14-bolt full-floaters in Suburbans? I was under the impression that the vast majority of the 14-bolts in the 3/4 burbs was the semi-floater. I was cruising the junk yard the other day and found two different 2WD suburbans with full-floating 14-bolt axles. They looked to be late 70's to early 80's models.
  2. R77K10
    R77K10 Banned
    Mar 15, 2006
    564
    Lincoln IL
    mostly 73-81 or 82 would be FF,, then after that mostly SF
    evne in the pickups, alot of them tended to be SF in the 80s
    a late 70s has a whole differen front clip design than an early 80s does,
    huge difference, simple to spot
    good luck
  3. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,486
    1,191
    So Cal.
    stay away from the 84/85 yr, they have the small pinion support bearing.
  4. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,548
    16
    Anchorage, AK
    My '81 k2500 burb had a SF14 and my '81 c2500 diesel had the FF14 bolt. Maybe the diesel is the determing factor?
  5. rlhenry
    Mar 6, 2002
    93
    Morenci, AZ
    I agree, the front clip makes it easy to separate the two. The problem I had with these two is that there was no front clip left on either one. There wasn't much left of the interior either as some of the gauges and interior trim can also help to determine model year. They both had tailgates instead of barn doors, but those were offered in a vast range of model years.
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    AFAIK, you didn't get a 14FF in a 81-91 Burb unless it had a bigblock.
    That didn't stop me from swapping one into my '84 though. ;)
  7. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,601
    550
    Wasilla AK,
    I imagine it has more to do with the GVW than motor your 2wd probaly was rated heavier than the 4x4
  8. u2slow
    May 9, 2001
    2,217
    BC Canada
    Maybe more to do with a cobbled-together truck? ;) :D
  9. AKbigsub
    Sep 9, 2005
    1,548
    16
    Anchorage, AK
    No, it came from the factory that way. !4 bolt FF with 4.10's. That axle is now undergoing the transformation to disc brakes. I have installed a detroit locker also. As soon as the brakes are done it will be going into the '90 burb:D
  10. u2slow
    May 9, 2001
    2,217
    BC Canada
    Naw... just giving you a hard time. :D I was thinking its either an '81 C1500 5.7L diesel, or an '82 C2500 6.2L diesel judging from dealer brochures anyways.
  11. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Just to add to the confusion of the "what motor determined what rear axle" issue I'll add to it.
    I had a neighbor ( oold man who bought his Burb new ) that had a 1990 4x4 Burb 6.2 / TH400-241 with a 14FF in it. I assume that the rear axle was as delivered from GM since this guy was a one owner.
    Now to add to the confusion, I came across another Burb almost identical 1990 4x4 GMC Burb TH400-241 / 6.2 (with the Banks kit that GM offered for a few years ) and it had the semi-floater in it.
    The "old man" Burb had 4.10 gears and the "Banks Burb" had 3.73's - those seemed to be the only differences between the two.
    I dunno...... Tom
